Best air blower for camera?
Posted 29/11/2014 - 22:39
davidstorm wrote:
It shouldn't be a problem using a Giottos Rocket blower, I've used mine many times with no issues. Remember to hold the camera facing downwards when you use the blower and you won't introduce more dust. I also change lenses very frequently and always hold the camera downwards when doing so. I don't have problems with dust on the sensor.
+1It shouldn't be a problem using a Giottos Rocket blower, I've used mine many times with no issues. Remember to hold the camera facing downwards when you use the blower and you won't introduce more dust. I also change lenses very frequently and always hold the camera downwards when doing so. I don't have problems with dust on the sensor.
I've only occasionally had a problem with dust, but using a blower with care and in a clean environment has only ever improved things, not exacerbated the problem.
But of course prevention is better than cure
Posted 30/11/2014 - 20:44
I'd never blow air inside the camera. Dust floats about in air so holding it facing downwards while doing so is of little help.
The high frequency sensor shake dust removal on start up on teh K-5 onwards has meant that after owning four K-5s I've never had to clean the sensor on any of them yet. Regularly had to clean the sensor on the K-20D and K-10 I owned. wet swabs I found are the best
A bit of dust inside a lens is nothing to worry about. Won't affect image quality
Posted 30/11/2014 - 21:56
McGregNi wrote:
David .. why do you blow air into the mirror box?
Who said anything about blowing air into the mirror box Nigel? When using a Giottos blower you set 'mirror up' and blow a defined stream of air at whatever is on the sensor to dislodge it, it is not just a general blowing of air into the mirror box. The Giottos blower is well established and is used by a great many photographers and I don't recall any complaints about it or this method.David .. why do you blow air into the mirror box?
I can't see why this is any worse than simply changing a lens and it has never caused me a problem. Why would air from a rocket blower contain more dust than the general air in the environment? If it shifts the dust from where you don't want it (on the sensor) then surely that is the objective? You mention using an arctic butterfly, yes great idea except for one flaw that no-one seems to think about. To use something like this you need the lens removed for a much longer period than you do to give it a quick blast with a rocket blower. The longer the lens is removed, the greater the chance of more dust entering, which once inside is likely to settle on the sensor at some point.
I can only speak from experience my experience is that the rocket blower has been effective in removing dust from the sensor.
As an aside, it has not been necessary to do this on the K-3 and I think I've only done it once or twice on the K-5iis. When I was using a K-x regularly it was affected by dust quite often and the rocket blower was pretty good at shifting it.
Posted 30/11/2014 - 22:56
Exactly the same for me - never had to do it on the K-3, just once on the K-5, regularly on the K-x
Posted 01/12/2014 - 18:28
Managed to change lenses, the cap was stuck tight and I couldn't move it until I was told I had to 'pull' it off instead of twist, so that was a bit silly of me
Beaubles are a nightmare to photograph. Going to do watches' with sparkly faces. Should I stay with F16 or F20-22?
Always be kind to people
link
https://www.facebook.com/pages/Photographs-by-an-angel/262352847143059
link
link
link
Posted 01/12/2014 - 19:42
F16, that would be good.
Posted 01/12/2014 - 19:49
f/16 will give sufficient depth of field and will still retain enough crispness to the image. By f/22 there will be distinct softening.
Posted 03/12/2014 - 10:09
Tried f20 last night, so see if that does anything
link
link
link
link
Posted 03/12/2014 - 13:54
kh1234567890 wrote:
Normally, when I change lenses, the shutter is shut over sensor ...
quite!Normally, when I change lenses, the shutter is shut over sensor ...
I've never bothered about which way up the sensor is facing and I've never wet cleaned the K20 or the Q, the built in sensor shaking seems to do the job for me.
However, getting back to the original question, the Giotto Rocket does a great job blasting dust away from camera parts. I recently fixed the pilot light jet on a gas fire with mine
Posted 03/12/2014 - 16:58
[quote:3496ace15f="gartmore]I recently fixed the pilot light jet on a gas fire with mine[/quote]was it a Cannon by any chance....
Posted 03/12/2014 - 18:54
was it a Cannon by any chance....[/quote] Sad to report it wasn't
Posted 03/12/2014 - 19:23
McGregNi wrote:
Going back to original question, I don't think its a good idea to use a blower into the camera with the lens off is it? I think you're more likely to blow dust into the camera. I would suggest not worrying about dust getting in - just change the lens indoors and point the camera downwards while the lens is off to stop any dust floating in from the air.
I would avoid carrying out any specific blowing or cleaning until there's a noticable problem. I would make sure the dust removal feature is activated to operate at each camera switch on. That should keep things ok for a good while.
Very good adviceGoing back to original question, I don't think its a good idea to use a blower into the camera with the lens off is it? I think you're more likely to blow dust into the camera. I would suggest not worrying about dust getting in - just change the lens indoors and point the camera downwards while the lens is off to stop any dust floating in from the air.
At first glance I thought the F16 attack fighter jetwash might be a bit harsh for cleaning dust.F16, that would be good.
Pays to read all the thread in the correct order!
