Best action case for K10D??
Posted 26/02/2007 - 22:23
I've got a lowepro rezo tlz 20. has strong velcro belt loop and D ring attachment points outside.
Take my k10 and 55- 200 lens
I use this for mountain biking but don't rely on the velcro loop, i put the bag strap through my backpack straps so there are several attachment points. Saying that it takes a lot of force to pull open the velcro.
Please call me aj,
Posted 27/02/2007 - 01:19
Hi Kevin:
If you live near a CAMERA STORE go in and look at their options and feel which one is best, and remember 1/4 for new stuff.
Hope this helps.
Hope this helps.
Posted 27/02/2007 - 08:20
Have a look at the LowePro slingshot bags. They're a snug fit (even into the smaller '100AW' I fit in a dl2, film body, 70-300, 28, 50, 18-55 and extension tubes ) Their design means they go from on your back to you front in a single slide. http://www.lowepro.com/
Posted 27/02/2007 - 08:28
Definitely agree, I have the 200AW. The AW stands for all weather, as they have a little waterproof cover that pops out of a pocket underneath. I was caught in a torrential rainstorm, and it didn't let a drop in.
An, as mentioned previously, it'll fit a body and at least 4 lenses.. plus pockets for your bits and pieces.
Liam
Liam
Liam
Posted 27/02/2007 - 17:22
Thanks for all th esuggestions, but they are just too bulky for the requiremnts I listed above, ie just to protect and carry SLR with attached lens, no additional pockets etc
Posted 27/02/2007 - 18:11
This Kata might be a bit too much for your needs:- http://www.speedgraphic.co.uk/prod.asp?i=16883&1=Kata+Holster+Case
and this Op-tech a little too basic http://www.speedgraphic.co.uk/prod.asp?i=8584&1=Op%2Ftech+D%2DPro+Digital+Pouch+black
I don't have the kata, but I use the op-tech for protection whilst walking around. I suspect that you need something like the kata holster with fewer pockets!
Or how about this: http://www.speedgraphic.co.uk/prod.asp?i=11783&1=Lowepro+Topload+Zoom+1
22 years
Needs to have sufficient padding to protect camera/lens;
But compact enough not to get in way when climbing/skiing etc, ie snug fit and no superfluous accessory pockets etc;
Needs to have option for belt attachment enabling bag to be slid from hip to behind back, and also detachable neck/shoulder strap;
What would be really useful is an internal fixing loop to secure camera strap (or strong cord to one or both camera strap fixing points) to protect against dropping camera without having to put camera strap around my neck before using it.
I need this to get more, and hopefully much better shots like my Vulture and ice climbing pics here
http://www.photo.net/photodb/folder?folder_id=444655
without worrying about dropping my new camera
Many thanks
Kevin
