Battery life on a K20D
They are relatively new as I buy new rechargables every 6 months.
I have always had battery grips for both my K10 and K20.
I use the cameras more or less everyday.
How often do you use your camera and what do you use it for, by that I mean what subjects?
Paul
With flash sometimes.
Most of the time Landscape.
What I do do is turn off the camera after I take a shot or 2.
Sometimes auto focus on sometimes off.
I never review my photos till I get home.
Remove the SD card and upload them to PC.
Not viewing them comes from all my years with MX.
When using a roll of 36 you spend a lot of time making the shot count.
Even with my K20D I can take 300 shots. Still do not to waste a shot.
Could be the reason I get battery life.
Did not get the same with my *istDL. Had to always make sure my batteries were fully charged. Kept extra with me at all times and a car charger if I need a quick charge. Was using 2700 too.
K20D, *istDL, MZ5, MX and MV
Leuven Belgium
-I use it 6-7 days a week
-I hardly ever use the flash
-Portraits, landscapes and macro
-I leave it on for how ever long I need it, it powers off after some time anyway. Most of the time it's in use
- Ditto about AF
-I review my photo's now and again, depends what shot I am doing, wildlife and macro, yes. Portraits alot, weddings hardly at all unless I have the time.
-Always remove the SD for upload
I have been using digital for 5 or 6 years now so the viewing is a must in certain circumstances, you may change how you do it in time.
I try very hard not to waste my shots, well it's not a matter of wastage really. Lets just say I'm not trigger happy!
I do class myself as a heavy user to my cameras. They are looked after extremely well. I have a K10 and a K20 and am thinking of getting another K20 to replace the K10. Not sure about the K7 as yet, still in 2 minds.
Paul
But even so, I was lucky enough to be in the Maldives a few weeks ago and I took just over 1000 shots in two weeks (needless to say I didn't get 1000 good ones! ) and my batteries never ran out!
They were running low on the very last day when I recharged them for the trip home when I knew I wouldn't be able find accessable power.
I have always been of the thought that you should fully charge batteries when they are as empty as they can be, so I never charge from only half full and this seems to do the trick for me.
To be honest I suspect i will run out one day just becasue I never worry about how much charge is in the thing! But just to make sure i always carry a spare charger in my bag, they're so light anyway.
Adrian
Plenty of stuff - not enough time....
And the older and more used a battery is, the less power it will store.
But it is pleasing to see that the K7's battery grip will take AAs!
I use my K20D every day at work for about 15-25 shot w/flash and w/o for industrial photos. The camera is used extensively on weekends for wildlife/nature and landscape shots (since January when I bought the K20D, I have over 12000 shots) I rotate the batteries when I see the "half-full" indication on the upper LCD.
K20D, SMC DA 18-55mm AL II, SMC DA 16-45mm, Tamron LD Di 70-300mm, ROK 800mm Mirror, D-BG2 battery grip, Kenko 2X teleconverter, loads of batteries. Sony DSC-R1 (Excellent portrait camera!), Sony HVL-F32X flash.
Leuven Belgium
I just now got a low battery indicator on the screen. I must say I am very please with how long you can go with 2 batteries on the K20D.
Leuven Belgium
