Battery issues
Check your contacts between the grip and body.
But having said that, I'll double check mine.
I have found that this 'decision' seems to be made at the time when the camera is turned on but it depends on whether the grip is turned on first. I have recently had the situation where the batteries in the camera died but the ones in the grip were ok.
Turning the camera on first displayed the flashing battery icon (dead) turning the grip on at that point made no difference ie, the camera did not then 'decide' to take power from the grip. Turning the grip on before the camera displayed a healthy battery icon even though the camera batteries were still dead (as you might expect).
I use 2350mah rechargeable NiMH batteries in my gear. I do think that it is important to use the same battery type in both camera and grip, but that's personal preference, I don't remember reading that it is mandatory.
Pete.
Like all electronic devices that are controlled by software you just have to find a way around the bugs, patches usually fix a 100 problems but in my experience they also create 10 new ones, welcome to the digital age!!
Brian.
If you take out the body batteries, the grip powers the camera - even if the grip is set to off.
My guess is that the firmware is going a little kooky. Maybe it's in some sort of half-standby mode when you leave the grip on.
I'll try some combinations and see what I get...
Am using 2 sets of 2400mAh NiMH
Andy
I think alot of the problems you are talking about in this thread could stem from the fact that you all seem to be using NiMH cells, as most do.
These batteries are great except for the problem of monitoring them. 1.2V per cell, everything OK, 1.1 V per cell everything shuts down when the camera wants to draw current, writing to card etc.
The discharge curve for NiMH cells is virtually vertical from 1.1V per cell, making any metering system difficult. In other words you wont get much warning with NiMH batteries, they either work or they're exhausted.
Leaving a battery for a few minutes allows the cells to partially re-form allowing a bit more discharge.
I think the metering system is tailored around Lithium batteries, these are what is supplied with a new camera after all, and have a much more gradual discharge curve than NiMH.
Chris
That's useful information for the forum.
However, these problems occur when you have two sets of fully charged NiMH as well. There's definitely something kooky when you use the grip.
I had it showing completely depleated battery, power off then back on, and it shows full. In the same session I took a shot, the shutter/mirror release sounded a "bit sick" and the camera powered off while saving the RAW file (losing it!). As soon as I removed the grip batteries, it was fine (From memory I had the grip on before powering up the camera... but I could be wrong!)
I'm gonna get to the bottom of this somehow...
Andy
Noted with thanks
Andy
21 years
Melbourne,
Australia
If I only have 4 more fully charged batteries, and I stick them in the battery pack, they're as good as useless, another shot or 2 and the camera dies; however, if I take off the battery pack and put them in the camera body, all is ok.
Also, it seems that if I turn the camera off but leave the battery pack turned on, the batteries in the pack go dead, is the camera meant to turn the pack off? It appears it doesn't.
Thanks all.
