batteries for k200d
Posted 30/12/2008 - 11:57
I tried Uniross 2700's in my K200 and had a similar problem, but the same batteries in my K110 work fine!
I've started using lower rated (2300) batteries which seem to retain there charge longer. I also use a battery grip which means I have 8 batteries in two sets in use at the same time, maybe that's why I don't have any problems now.
Cheers, HG
PPG entries.
PPG entries.
Posted 30/12/2008 - 13:23
yes i have just been looking at those (sanyo eneloop) and thought i would give them a try. how are you finding them?
Posted 30/12/2008 - 13:29
A standard NiMH battery normally looses about 10% charge after the first day, then 0.5 - 1% per day at room temperature thereafter.
There should be plenty of charge left after two weeks unless the battery is faulty or was not fully charged in the first place.
You can also use lithium AA. Look out for Energizer Lithium on special offer at Tescos, Jessops, 7dayshop, etc. These are more reliable and a lot lighter than NiMH rechargeable batteries.
~Pete
Posted 30/12/2008 - 13:53
There are chargers and there are chargers. Most use a timer to decide when the battery is charged (Energizer, Uniross etc chargers). What you ideally need is a charger that is intelligent. When I bought the BL700, it was like the secret of the universe had unfolded before my eyes, and suddenly batteries that were lasting half a day int he K100D were now lasting for several days (your mileage may vary). Also consider the batteries. Uniross hold their charge for the longest, but generally fail much quicker than other brands. I have got through three sets of Uniross 2500mAh to one set of Duracell 2100mAh (and still counting). Have a look at the charger I mentioned here
Again, your mileage may vary.
Posted 30/12/2008 - 15:55
I'm using energizer Lithium in my K200D, they go on for ages! I've heard about these Eneloop ones but can't seem to find them anywhere? - are they easy to source or am i just as blind as a bat?
Fortune favours the brave.
Posted 30/12/2008 - 15:56
For my flash I use these Varta Professional Have bought them with a digital charger that can also be pluged in into the car sigarete lighter, so if in emergencies I can give them some juice
I don't have enloops so I can't compare them but I've a set of 2 and if one set is depleted, they get recharged and go in the bag for a month or 2 before they see some use again and I can't really tell the difference if they are freshly charged or not. The Vartas are also 2700mAh compared to Enloop 2000mAh so there really is some difference even if they lose some more charge
Posted 31/12/2008 - 12:03
i just got some uniross hybros. looked at reviews comparing the uniross hybros and the sanyo eneloops, and all the reviews were the same stating that they were as good as each other but the uniross lasted longer due to be more (mah)uniross 2100mah and eneloops 2000mah.and also a goot 8 hyrbros for £ 12 delivered.
also got some aaa eneloops back a long for my daughters camera and they do last very well,
so will give these a try. report back when a have a time to try tham properly.
just keep snapping,
nikon d300 + battery grip.
sigma 150-500mm apo dg hsm os
sigma 170-500mm apo dg
Posted 31/12/2008 - 14:36
Although I am new to DSLRs, I have some experience with rechargeables from another hobby, RC flying.
Generally the modelling fraternity as a little sceptical about 2700mAh NiMHs. They seem to loose capacity after relatively few cycles. I had a set in my transmitter for a while, then replaced them with 2000mAh cells and got a longer usable time. In model flying, Sanyo cells are considered th be the cells to have.
Just a quick to those who have Li-ion or Lipo cells - be nice to them, or else this happens
Clicky
Clicky
Posted 31/12/2008 - 14:42
cheers oggy i got uniross 2700 mah and enigizer 2700 mah and they aint lasting as long as they should, but the cold dont help.
just keep snapping,
sussex,
uk
