batteries
Posted 18/12/2010 - 16:10
My brother-in-law is still using whatever batteries came with the camera some three months later, and he's shot hundreds of images. So replacing with similar might be a good choice.
Posted 18/12/2010 - 16:28
My advice would be carry a pack of Duracell as backup then see how you get on with the rechargables. There are a number of factors affecting how long each set of batteries will last.
Posted 18/12/2010 - 16:58
If your K-x is like mine - it comes with Energiser Lithiums - and I got about 1000 shots from these [ camera bought in November last year ] I'm now on my second set and I suspect that they will last for some long time yet.
p39 in the manual says
Lithiums recommended in cold weather
NiMH these are economical. A commercially available battery charger that is compatible with the batteries is required
Alkaline batteries - easily obtainable when the batteries you are using run out but they may not support all the camera functions under certain conditions. We do not recommend using them except in emergencies or when checking the camera functionality
BTW a new camera deserves new batteries - ie a brand new never been used set .
let the education continue
Posted 18/12/2010 - 18:18
the ones i have are still in the packaging as is the charger
BTW a new camera deserves new batteries - ie a brand new never been used set .Lithiums recommended in cold weather
Posted 19/12/2010 - 00:45
I use 2300 Nimh..I get 3 to 400 shots per charge...depends on how much I use the screen or flash..
Stuart..
Stuart..
Posted 19/12/2010 - 19:11
One advice, test that your K-x really works with your rechargable batteries. Discharge batteris and charge them at least one time before using them.
I have difficulties with my K-x and NiMH batteries and now I bought new Sanyo Eneloops (2000 mAh) (not Sony as I wrote earlier), see link
My K-x seems now to be working, but I've only taken ten photos with Eneloop and I don't know how long my K-x works with Eneloops.
If it's possible take Lithium batteries as a backup.
Best Regards
Jukka
flickr
"If your photographs aren't good enough, you're not close enough." - Robert Capa
Jukka
flickr
Posted 19/12/2010 - 23:31
There are new "eneloop" type batteries available from sanyo.The XX or double X (not really sure). These are the same type of "low self-discharge rate" cells as eneloops, only they have larger capacity of 2500 mAh.
Eneloops proved to be very reliable cells with my flashguns and K200, so in my opinion, these are worth trying.
cheers, Luka
cheers, Luka
Link to my PPG
Posted 20/12/2010 - 12:09
In my K100D I used the "eneloop" type batteries having originally used std NiMH.
The standard NiMH rechargeables were very unreliable - I could charge them one day, put them in the camera, take a few shots and they would be flat 3 days later with little or no more use.
The eneloop/duracell precharge type batteries are similar in behaviour to the lithium batteries that came with the K7 and solved all of my battery headaches for the K100D.
However, I stll always had a pack of "Copper Tops" in the bottom of the bag just in case!
Cheerz
MZ
Cheerz
MZ
K5, K7, Nikon FA.
AF Lenses: DA15mm Ltd, DA21mm Limited, DA35mmAL, DA50mm f1.8, DA18-55mmWR, FA28-70mm f4AL, DA50-200mmWR,Tamron SP70-200mm f2.8, AF70-300mm LD Di, SP10-24mm, SP90mm Macro.
MF Lenses: SMC-A 50mm, Adaptall 24mm(CW-24), 135mm(03B), 35-70mm(17A) 80-210mm(03A), Micro-Nikkor55mm, Soligor I-S 200mm f2.8 AIS
My Flickr - link
My Photobucket - link
My Flickr - link
obviously i will take spares when im out and about, but just wandered really
cheers
mat
