Auto White Balance...?
Posted 07/04/2010 - 17:47
so I took it for a few test-shots around the park (until it started to rain...grrr...)
Thank yourself lucky that spring is here, I got my K10D and Sigma 50-500 for xmas a few years ago, it was about four weeks before I actually got outside to use it properlyso I took it for a few test-shots around the park (until it started to rain...grrr...)
The 50mm should be very nice though.
Posted 07/04/2010 - 18:03
Maybe it was Purple Rain?
It is possible that the camera has set the wrong W/B in some of the shots. Perhaps try again in different weather conditions to see if you get more consistent results then. I took some Panoramic shots with my K7 and one image was a different W/B to the rest. And once i took some Shots of a Harrier in a hangar but when a guy entered into the scene wearing black overalls the W/B changed! but it is not a common occurrence and i shoot in RAW so no big deal. Those have been the only occasions in 14,000 exposures with the K7.
Regards - Pete.
Regards - Pete.
Posted 07/04/2010 - 18:19
I never use AWB; mine's permanently stuck to "Daylight" unless I'm shooting under tungsten lights when I'll change it to "Tungsten". Works fine for me and it's always consistent!
Joining the Q
Posted 07/04/2010 - 18:22
If you are shooting RAW you can set the white balance when you convert it.
My K20D lives on AWB and gets tweaked when I convert. Mostly I am very happy with AWB.
I would retest your lens with the white balance set either to daylight or to a custom reading you take yourself.
Posted 07/04/2010 - 18:27
Me too.
Posted 07/04/2010 - 19:02
I tend to leave mine on AWB shooting JPGs, I usually take one test shot and have a quick look, if it looks ok I leave it. I only tend to change the settings if (for example) people come out orange, which generally means I need the Tungsten setting!
Posted 07/04/2010 - 19:48
Same here - I am usually very impressed with AWB and a little PP sorts any mixups. It seems to struggle with sand for some reason.
Posted 07/04/2010 - 20:07
Thanks all.
Not had any AWB issues before, but it was a very changeable afternoon and its a new (to me) lens!
I will stick it manual white balance for now, and put the camera (with each lens) on a metered chart at the weekend.
Posted 08/04/2010 - 15:09
Thanks to the blazing sunshine that mysteriously appeared today (!), I went back and took exactly the same shots-ish : tilted the camera from about 45 degrees down to horizontal and took 3 shots like before
Fixed the colour-temperature to "Outdoor" just to be sure. And (small fanfare please) the tarmac path with the variable purpleness was the right colour today, hurrah!
Moral of the story - use fixed colour-balance when the weather is changeable and you are tipping the camera up and down - they can only guess from what they see!
Posted 08/04/2010 - 15:21
Are you using the lens set to "A" on the aperture ring?
I only ask this as my Pentax-A 50mm 1:1.7 is fine AWB-wise when using the "A" setting, but when I tried setting the aperture on the lens rather than body I appeared to enter a new dimension, one where AWB is about as much use as a chocolate teapot!
Other than that, shoot RAW and the problem is easily resolved in PP.
Apparently.
Apparently.
Posted 08/04/2010 - 15:22
I all depends, if you're taking pictures of air hostesses or perfume counter ladies, the orange might just be correct!
Apparently.
Apparently.
Posted 08/04/2010 - 15:30
Yes I am using "A", and always shoot RAW. I was more worried I either had a duff lens or wasn't using it right!
Twickenham
Anyway, when I looked at them, some of tarmac paths looked a bit purple, but others weren't so noticeable. I scratched my head for a bit, then tried playing with the White Balance - voila, solved! But its not consistent from shot to shot, argh.
Shooting Av Mode with +1 EV, RAW, Auto White Balance, sRGB, and converting using Pentax DCU 4.
Should I be setting the White Balance by hand as well? Or am I making a different beginner's mistake...
As it was a pretty cloudy/rainy afternoon I can understand the camera could be getting confused...! Didn't have an alternative lens with me to compare, annoyingly.
