Auto flash control, TTL and P-TTL
Manual control allows better balancing of flash and 'background' light as well. There will certainly be many more expert people here who will understand the specific functions your Pentax unit offers, but for manual work you really need a distance readout scale, or LCD indication of the correct subject distance.
You firstly set the ISO and aperture on camera, then either repeat these settings on the flash (or confirm the flash has read them from the camera), then read off the correct 'flash to subject' distance from the flash display. If you cannot get far enough away for this distance, then you have two options - either stop down the aperture further, or reduce the flash power (eg 1/2, 1/4, 1/8 etc.)
Your choice of which to do would really depend on whether you had a need for a specific aperture for a depth of field effect. If you didn't want to stop down then you must reduce the flash power to achieve the correct flash exposure. Different flash models will have different means of displaying the required information.
For Fill flash use, you would want to reduce the power more than recommended for correct flash exposure (say half or so), also by stopping down or reducing power further, again depending on the subjects need for any particular aperture. I do feel this approach will ultimately give consistent and more precise results than any automated TTL system.
On your camera, with the flash mode switch set to Auto, you will only get 1/1 (100%) flash discharge.
Your flash can however be used on either of it's manual settings but these are very limited at 1/1 and 1/4 output.
It is unlikely that the flash compensation set on the K30 body will actually affect the flash output.
Time to get a new flash I think
Pentax, Metz, and Sigma produce P-TTL compatible flashes.
P-TTL is a bit hit and miss and you wont get constant exposures, but I don't think your flash supports P-TTL?
The link below will provide a wealth of info in relation to Pentax & Flash
http://pttl.mattdm.org
http://www.cs.mtu.edu/~shene/DigiCam/User-Guide/FZ-10/Ext-Flash/Flash-Auto-Mode.html
Well worth a read.
As an aside, why did Pentax discontinue TTL support? Cost-cutting, or because P-TTL is seen as the future?
Ta all, useful insights - shame that it seems I'll lose the simplicity of fill-flash through TTL.
P-TTL works differently by produceing a preflash & monitoring the illumination produced by that with the camera's main sensor. In use it is generally as simple to use as TTL unless you are using optical slaves to set off other flash guns. (If you try the preflash sets of the slaves, which are then recharging during the main flash). The effect is not dissimilar to the anti-red eye pre-flash.
I have to admit I find P-TTL invaluable for macro, where I hold the flash in my left hand at various angles/distances from the subject. Manual would be totally impactical here as the flash-subject distance is too uncontrolable.
(I suspect the answer is yes, as it sounds like the difference is more one of how the flash light is measured than anything else, but thought I'd ask to make sure!)
Compensation is rated in 'stops', as in aperture values, so -0.5 (half a stop), -1.0 (1 stop) etc. I use minus because for fill this is the more common direction to head in, as we are not trying to completely illuminate the subject (which will have ambiant light on it), but rather to 'fill in' darker areas like shadows on faces or under the brim of a hat.
Of course, despite the different units of control input, we are effectively doing the same thing. 1 stop less of flash would be the equivalent of 1/2 power I believe.
As far as 'computing' this value, well I'm not sure if there is a formula or not! But, its something that comes with experience both with the subject type and the particular camera also - flash exposure metering is affected in the same way by a subjects 'reflectivity' just as ambiant light metering is. So, for example, a light toned face would require a bit more fill flash than a dark toned one. I've always understood that a good starting point for most fill situations is -1.5 stops. I'm sure others will have other experiences to relate as well.
Flash exposure Compensation is actually controlling flash power output - so -1.0 stop caused the flash to fire at 1/2 power, just the same as if you dialed in 1/2 power on a flashgun.
Much easier just to dial in 2 stops' flash compensation and tweak if anything looks washed out or a little flat.
I've serious respect for the guys who could do all the manual calculations 'on the fly' in the days of old, but I'd prefer to leave that sort of thing up to the tools, if at all possible.
Just as an extra thought here, it's perhaps worth mentioning that even though we think of Flash Exposure Compensation in terms of 'Aperture Stops', it is not of course actually affecting that actual aperture setting of the lens (only the lens aperture ring or camera control wheel will do that).
Have I got this wrong?
Flash duration would have an effect only at longer shutter speeds, ie beyond the 'Flash Sync' speed (180th sec on my K7) - generally the flash duration is significantly less (faster) than the shutter is actually open, so in these conditions just reducing the flash duration would have no effect.
Quoted from above ... 'The 'units' (if you like) for flash power and flash exposure compensation are different - power is rated in fractions of full output, so 1/2, 1/4, 1/8, 1/16 etc.
Of course, despite the different units of control input, we are effectively doing the same thing. 1 stop less of flash would be the equivalent of 1/2 power I believe'
22 years
GB
I have an AF400FTZ and I'm trying to figure out how best to use it on the K30. I generally use it for a bit of fill, but I can't seem to get a decent effect. A brief reading of the forum suggests that the flash is TTL and the K30 only supports P-TTL, which might be the source of my problems. Does the flash exposure compensation, as dialled in through the body, have any effect, or am I must being dull?
