auto bracketing
Posted 18/02/2010 - 11:22
Don't forget that there are several different Auto-bracket setting too.
You can choose 1/3 or 1/2 EV steps, you can have 3 or 5 exposures, choose the order (-0+, 0-+, 0+-, +0-) and if you want you can add in exposure compensation (over or under) to bias the bracketing.
Posted 18/02/2010 - 11:51
What's the best space you can use between the shots?
Around the O,7EV maybe or can you use wider without much problems?
Posted 18/02/2010 - 13:19
I use M.
Set to a reasonable mid point, test. Then take as many shots as necessary (at least 7), varying from almost pure blow-out to darkness. Normally with 2-3 clicks of the wheel between each one.
Bret
Bret
my pics: link
Posted 18/02/2010 - 15:12
well I've looked on the net and found that AV is best so there is no change in DOF
But know it's snowing so I may not get out this week. But my son Has a really nice chapel so will have a go next week as they are of school this week
James
James
Posted 18/02/2010 - 17:23
Hello there, As I was advised by the forum members, In user mode. I use av mode auto braket 5 shots, 2 steps apart, however you can adjust to your requirments, I then use photomatix pro to compile my image then render it as a HDR image, After this clean it up in adobe photoshop. Hope this helps
https://www.flickr.com/photos/carlosimagery/
http://twitter.com/foxycce
http://foxycce.ontheroad.to/carlo-does-thailand-tour
Karma is Just Cause and Effect - Do Good, Good will Happen
Posted 18/02/2010 - 18:27
I under stand that photomatix is free to use but leaves a watermark on the image.
how big is the watermark and where is it placed
How much is photomatix to own
James
James
Posted 18/02/2010 - 18:43
mike very nice shot and not over done. How much of a watermark is the free version of photomatrix leave on the image
JAMES
JAMES
Posted 18/02/2010 - 19:08
THANK YOU MIKE
for £60.00 I'm going to get the pro stand alone program.
but I am also impressed with the B&W plug-in witch I will be getting in march.
James
James
Posted 19/02/2010 - 11:46
If you set the K20D to take all the shots with one push of the shutter button I have found you can hand-hold OK and use photomatix's "align features" check-box. It is safer on a tripod of course, but is an option when you are without one. I always go for five shot at 1.5EV spacing in Av.
K.
K.
Posted 19/02/2010 - 18:35
Thankyou K
I will take on board what you have said
James
James
Warwickshire
what is the best camera program to use on my K20D is it manual, auto,av or what.
I've never done this before so advice welcome
James
