Attempt at manual focus etc.
Posted 21/01/2010 - 00:00
The focus looks a bit more on the wall and a little less on the pull to my eyes, don't you think?
Best wishes, K.
Best wishes, K.
Posted 21/01/2010 - 08:34
Yes, the pull is out of focus but the wall spot on.
Keep trying Colin, manual focusing takes a lot of effort to get right, but once you get the hang it's well worth it.
A Katz Eye screen would help if you intend doing a lot of manual stuff( note to self must get one some time!).
Cheers, HG
PPG entries.
PPG entries.
Posted 21/01/2010 - 11:42
Hi Womble, Greytop & Hardgravity,
I agree with the comments regarding focus, I will get a Katz Eye screen at some stage this year.
But will also have another go (differant subject) ASAP.
Thanks for the comments
Colin
Edmund Burke (1729 – 1797)
Posted 21/01/2010 - 12:48
Doubtless a different screen will help with manual focus, but there's still no reason why AF confirmation shouldn't enable you to focus manually, and have the camera tell you it's in focus.
Using the green confirmation hexagon in the viewfinder works fine for subjects like this. You just need to be sure it's using the centre AF point, and, very importantly, not move the camera after you have focus confirmation.
It doesn't need to move much, especially with a close subject like this one, to spoil it completely.
Posted 21/01/2010 - 13:05
I'd forgotten about setting focus point, I have mine on centre all the time!Using the green confirmation hexagon in the viewfinder works fine for subjects like this. You just need to be sure it's using the centre AF point, and, very importantly, not move the camera after you have focus confirmation.
You could also enable 'catch in focus', but that can be hit and miss as well.
Cheers, HG
PPG entries.
PPG entries.
Posted 21/01/2010 - 15:26
Ehhhhhhhh.....When using MF lenses the centre focus point is automatic selected. No way it will be set at an other point.Quote:
The green hexagon has some latitude to play with. Depending on which camera you use. You will notice you can turn the focus ring for a certain amount, whit out the green hexagon disappearing. The will effect critical focus.(specially with the lens set at wide open)
You might also check the dioptre setting, on your VF. That can also influence the way you "see" something in focus.
Posted 21/01/2010 - 15:30
Nice to see you back Martin
In my experience too the focus confirmation is not accurate enough for close up focussing. Split prism screen is the only way to go.
Posted 21/01/2010 - 15:39
Thanks peter, it is good to be back.
Posted 21/01/2010 - 18:16
Yes, I'd certainly agree with this. I've got very used to positioning the ring as close as I can to the middle of the range over which the hexagon is lit, which seems to work for me.The green hexagon has some latitude to play with. Depending on which camera you use. You will notice you can turn the focus ring for a certain amount, whit out the green hexagon disappearing. The will effect critical focus.(specially with the lens set at wide open)
However, unless there's a back focusing issue, the latitude you describe isn't as great (at least not on my K10D) as it would have to be, to account for the substantial focus error in the OP's picture.
Posted 21/01/2010 - 18:20
So it is! I'd forgotten that.
Why is this the case, do you think? Why shouldn't it be able to use the other AF points, just because MF lens is stuck on the front?
Posted 21/01/2010 - 18:37
Hi Chris,
I think it is plain old fashioned "Old School" thinking by the design dep.
Because the focus area of MF was based on the location of the split screen/RF patch in the past.
A more likely reason could be: Their is no electronic linkage between original MF lenses and modern Dslr's except the contacts who give the aperture info. ( Pentax A lenses) So how could there be communication between the movement of the focus ring and the camera electronics ??
TBH.....I don't know if selecting a different focus point is possible
using MF with DA lenses. I never tried that. I always used real MF lenses.
Posted 21/01/2010 - 20:34
Just tried it out... the focus point is selectable when using a DA lens (in this case my kit lens) and manual focus but defaults to the centre point with older lenses (in this case an SMC-A 50mm f/1.7). (This was with the K20D, I assume the K10D will be identical.)
Best wishes, Kris.
Best wishes, Kris.
Posted 21/01/2010 - 20:46
Thanks Kris,
I'll guess this makes my thoughts about the lack of electronic linkage between dslr's and old mf lenses correct, as the main reason selecting different focus points is not possible.
Bedford
[IMG]http://i941.photobucket.com/albums/ad254/weldingblues/Lightpull.jpg[/IMG]
C & C please
