ASAHI PENTAX SP500
Posted 30/04/2013 - 18:28
That lens caps worth a fortune!!
Posted 30/04/2013 - 20:37
Well make me an offer kidda and it is all yours
Posted 09/05/2013 - 22:51
Recently picked a CZJ 135 zebra up for £10.
Already have a SP500.
Nice to use together, when will we see some shots using this nice setup?
Cheers, HG
PPG entries.
PPG entries.
Posted 08/08/2013 - 14:33
Are you aware that the later SP500's had the 1/1000th of a second shutter speed? Not marked on the shutter speed dial there is another 'click' after the 1/500th of a second position, this will give you 1/1000th of a second. So the only difference between the cheaper SP500 and the more expensive SP1000 was the writing on the dial.
Chris
Posted 08/08/2013 - 21:57
Always amazes me to see mint bodies like this, mine are individually customised with brass showing and asymmetric profiles
Posted 11/08/2013 - 12:06
I thought that was on ALL Sp500'sAre you aware that the later SP500's had the 1/1000th of a second shutter speed? Not marked on the shutter speed dial there is another 'click' after the 1/500th of a second position, this will give you 1/1000th of a second. So the only difference between the cheaper SP500 and the more expensive SP1000 was the writing on the dial.
It has been on the several I've had any way...
Cheers, HG
PPG entries.
PPG entries.
Posted 16/08/2013 - 23:39
My Dad has one with a particularly amusing customisation, the pentaprism must have taken a whack at some point in its life, so that the world as viewed through the SP500 is always at about 10 degrees to the horizontal. Makes composition....interesting
but it does help
but it does help
Northumberland
