Aperture values
Posted 30/12/2012 - 12:01
I have always assumed that aperture value meant the maximum aperture available at that particular zoom setting (most zooms have variable apertures) and that f stop was the stop actually set by the user. It would be easy enough to test out this theory and I may do so when I get a moment.
It won't refer to transmission values (T stops) because a variation such as that indicated would be very excessive indeed and rather unlikely given modern multi-coating techniques.
Posted 30/12/2012 - 13:15
It is explained there, althoug it seems a bit over-convoluted to me as explanations go. One day I'll look into it.
Posted 30/12/2012 - 14:01
There is no discrepancy.
Take as an example an F-stop of f13. The corresponding "aperture value" will read 7.4.
Why? Av is formally defined as 2 x log(base2) of the aperture. So 2 x ln(13)/ln(2) is ~7.40.
Why log(base2)? Because each whole number increase represents a doubling, i.e. one stop.
Why multiply by 2? Because the amount of light let in by a given f-stop is proportional to the aperture's area rather than its diameter, so the aperture squared is the key variable.
A fuller explanation is here:
http://en.wikipedia.org/wiki/APEX_system
22 years
Handsacre
If you look they are completely different, e.g.
F-Stop: f/11
Aperture Value: f/6.9 .
Shouldn't they be the same?
ONE UNITED Member
