Anyone using their DSLR for video
Posted 10/07/2014 - 08:06
Oh dear ... would your K30 do the same? At least those who us have have migrated to the northern hemisphere don't have to contend with so many ceiling fans Looks like you might need that K511S
BUT - that 645Z video was shot on a tripod ... you're not supposed to use SR on a tripod are you???
Posted 10/07/2014 - 09:54
Agreed about the tripod, but even on a tripod, mechanical in camera shake reduction wouldn't necessarily have a problem with that speed of pan. a tripod ... you're not supposed to use SR on a tripod are you???
The case shown in this video is entirely software shake reduction generated.
When you see how many options there are for the warp stabiliser effect in Adobe Premiere, and how long it takes even on a grunty computer, you realise that software shake reduction on the fly is always going to be quite an ask.
Just thinking about it, if the stabilisation was done mechanically then presumably the loading on the processor would be less, in which case focus peaking during video recording, or higher bit rates etc would be a possible substitute
Posted 10/07/2014 - 10:52
I assumed that my K7 (& sensor shake SR systems generally) would not have any software stabilisation going on at all? So are you saying then that the 645z example there would not be better with SR off on the tripod (the slow pan bit I mean) ?
Posted 10/07/2014 - 21:26
All Pentax IL cameras since the K-5II use software SR (MovieSR) in video mode regardless that mechanical stabilisation is available and used in stills mode.I assumed that my K7 (& sensor shake SR systems generally) would not have any software stabilisation going on at all?
No, he's not saying that at all.
Posted 10/07/2014 - 21:32
Ok, thanks, so why did they use SR on a tripod then for that clip? Is it not then just an example of incorrect operation?
Posted 10/07/2014 - 21:36
I'm pretty sure that's correct. The earlier models used 'real' mechanical stabilisation, just like they all do now for stills photography. The newer ones appear to use software stabilisation during the video mode.I assumed that my K7 (& sensor shake SR systems generally) would not have any software stabilisation going on at all?
Basically yes, that's what I'm suggesting. are you saying then that the 645z example there would not be better with SR off on the tripod (the slow pan bit I mean) ?
If you think about why you had to turn it off (or why it was suggested to) during panning, it was because the sensors would detect movement (during the start of the pan especially) and assume it was (unwanted) camera shake and start to correct it.
With an image/visual assessment only based system, the camera is not using any information from the physical movement sensors. It's having to evaluate what's changed in the image from last time, and how it should manipulate the image (rotating it, sliding it, warping it perspectively etc) to keep it steady. (This is why the image is cropped on the newer cameras also, as you need to leave some wiggle room to move the image around and still be able to crop a constant bit out from the middle.)
I can't stand this guys voice, but check out how long Premiere takes to calculate the stabilisation on a 4 second clip here
And here's a much nicer quick overview
The fact that the 645Z footage tilted up smoothly in that video shows that it's perfectly happy with that level of movement. What throws it is spinning fans, which software wise it detects as a bump motion and it begins correcting for that. You could have hand held that tilt up and encountered the same issue.
If real physical movement sensors were being used then the camera would know that this area of the shot was not camera shake, and was not to be treated any differently from the initial tilt up movement part of the clip. There was no new/different bump or movement shake at that point, so the shake reduction should never have kicked in.
Posted 10/07/2014 - 21:55
Yes, you're right Richard ... The K7 has no problem with moving or spinning objects and only responds to actual physical camera movement. I have sensed your frustration at times that (as Sledger just said) the 'mechanical' system used for stills is there in the newer bodies, but just not implemented during video recording. So as I know you've asked before, why can't a firmware fix be offered?
But hang on ...isn't camera operation basically very similar during both Live View stills mode & video mode? Presumably sensor shake reduction is available in Live View, so why not for video? I guess someone felt the software solution was an advancement & more sophisticated ...and maybe they mostly have condensing air conditioning in Japan and very few rotating ceiling fans?
Posted 10/07/2014 - 22:34
Interesting thread. I don't video much, but I have used the K-01 and the K-x. I've also tested video on the K-5IIs and quality is very good. My comments would be:
- K-01 is a decent video machine, but bitrates could be higher
- Always turn off the Movie Mode SR, it is pants
- For anything other than completely stable light conditions, on the K-01 make sure you fix the exposure, otherwise the image will keep going darker and lighter as the auto exposure tries to compensate
- K-x is a good little video machine, but only 1280*720 resolution
- K-5 series are the best for video in quality terms, not many options, but very good IQ
I would guess the K-7 is a tad behind the K-5's for video image quality, especially in dim light.
Posted 11/07/2014 - 00:45
Yeah I'm actually very passionate about the brand and find it extremely easy to talk it up against the competition in stills mode. The K-30 has a large, full coverage pentaprism viewfinder, excellent sensor, is weather sealed, has two control dials, has a (potentially dodgy) intervalometer, an electronic level, a 1/6000th of a second max shutter speed, internal image stabilisation of all lenses attached, shoots at 6 fps, doesn't cost too much, can take AA batteries at a push etc. Seriously I love this stuff and that via Pentax I can afford it, and that the body feels great and that the user interface seems quite sensible to me.I have sensed your frustration at times
The newer software models, from the q, K-01, K-30, K-3, 645z etc all have much more flexible video controls. In that there is an option for full manual control for a start plus the options for 1080p 24 fps. That really is all great and it is a real step in the right direct. However, they then go and stuff the stabilisation, and don't allow the cool stuff when you use the video, such as focus peaking, which I feel I could really benefit from, given the way I use lenses most during my shooting.
Even if you turn 'Movie SR' off, which instantly removes one of Pentax's strong marketing points of IBIS, the screen is still cropped down, so if you then apply your own image stabilisation afterwards it will have to be cropped in tighter again still.
I don't like how this is often dismissed as "it's a stills camera", "I never use video anyway", "you shouldn't have brought a Pentax for video anyway" etc. It IS there, some aspects are already very good, others don't work particularly well, it could be awesome with a tiny bit of effort, end of story really.
Oh what I wouldn't give for just 10 minutes with an actual Pentax software developer!
Posted 11/07/2014 - 03:06
They would have to be 10Kms underground in a lead lined concrete bunker to not be fully aware of the discontent by now.
Posted 16/07/2014 - 08:47
TheCameraStoreTV 645Z review
Thought I'd link to this as an example of the Video influence on digital cameras these days. IF you are going to include video in your product, then it is going to get reviewed. Therefore it's in your best interests to do a decent job of it!
North Island - New Zealand
Pentax video gets a bad press around here for sure. But there are links on here pointing to good quality examples
This system is in place in all modern Pentax bodies, from the K-30/50, K-01, K-3, 645Z, and Q - and it's a total embarrassment that is genuinely hurting the brand image. It's much worse than the K-5 series and older models with Video capability. Pentax has long traded on it's ability to stabilise any lens due to it's in body stabilisation, but several other brands have this now, and they actually use it during video recording too!
