Anybody used Harrow Technical for repair?
Posted 25/01/2013 - 08:09
Dave - there is a thread here (somewhere) about a guy in the Teddington area that does camera repairs. I think he also fixes opticals too. I'll try to find a link for you...
UPDATE..
I couldn't find the specific article here, but thankfully I (sorta) remembered this guy's location (one of my drivers lives not far from the repairer) and done a web search. Try this link
Best of luck!!
UPDATE..
Best of luck!!
Posted 25/01/2013 - 08:17
Thanks for that Steven!
Digital:
Flash:
Film:
Digital:
Flash:
Film:
Posted 25/01/2013 - 08:22
I've never taken a Pentax-A 35mm 2.8 lens apart, but normally
when you remove the front, there are 3 small grubcrews that grip
the focusing ring. It sounds like they have worked loose and
just need tightening...... should only take about 10 mins.
Posted 25/01/2013 - 08:30
This guy could be usefull
http://www.alan49.x10.mx/index.htm
Posted 25/01/2013 - 08:33
Very useful, have used him quite a few times ... decent prices and excellent service.
Posted 25/01/2013 - 08:37
This is a Takumar, but you can see the 3 screws. On this
lens just the beauty ring needs removing to access them.
The A Series doesn't have a beauty ring so the front
might be held by grubsrews into the body.
http://retinarescue.com/pentax50mmf1.4.html
Posted 25/01/2013 - 09:45
I have also used A M Technical to repair my 55-300. Good efficient and cost wffective. Give alan a call and discuss your lens problem.
Stuart..
Stuart..
Posted 25/01/2013 - 13:23
Asahi Photo in Brentford are good too. He's serviced my Z-1s...
AKA Welshwizard/PWynneJ
Posted 25/01/2013 - 14:06
I never even knew this place existed! Asahi Photo in Brentford are good too. He's serviced my Z-1s...
It's not too far from where I live too!!
Posted 25/01/2013 - 15:44
I think the A35 F2.8 is similar to the A50 F1.7. The plain plastic ring that sits between the front element and the filter ring can be removed to reveal the three screws that have most likely worked loose.This is a Takumar, but you can see the 3 screws. On this
Regards - Steve
Posted 25/01/2013 - 17:55
How does one remove this 'beauty ring' without damaging the glass then?
Digital:
Flash:
Film:
Digital:
Flash:
Film:
Posted 25/01/2013 - 17:57
Nevermind... Link shows me!!! Sorry!!
Thank you all!!
Thank you all!!
Digital:
Flash:
Film:
Digital:
Flash:
Film:
Posted 25/01/2013 - 22:12
Thank you all!!
Thank you all!!
Pentax K5D, Pentax 16-45mm f4 DA ED AL, Pentax 55-300mm ED, Pentax 100mm Macro f2.8 D-FA, Tamron 28-200mm, Sigma 170-500mm.
Posted 25/01/2013 - 22:18
Hello,
I have just rejoined after a short period offline.
As regards Harrow Technical I have used them twice and i have been very impressed with their service.
I have sent two lens for repair, the first was my Pentax 100mm f3.5 AF Macro lens when the aperture got stuck somehow. I think something happened when I tried attaching it to a cheap set of manual extension rings. Anyway they managed to sort the problem and I have not had anything happen to the lens since.
The other lens i had repaired was my 400mm MF Sigma lens. One of the internal elements was totally covered in little tiny dots (a fungus) so every photo i took with it appeared blurred. they stripped it down chemically cleaned the lens element and now its fully functional.
So I have no hesitation in recommending them myself. I have not used anyone else so can't comment for other companies.
Bradford
The glass is nice and clean... No fungus... Aperture is snappy... But it won't focus... At all...
Feels like the focus ring is un-connected... Loose.. Slack... Not right...
Thinking Harrow Technical are my best bet... Hopefully won't cost more than £50 to repair...
Anybody used them on a similar repair?
Is it even worth it, or should I just bin the lens?
Is there another lens repair place I should check out?
Advance thanks
Dave
Digital:
Flash:
Film:
