Anybody used Harrow Technical for repair?
UPDATE..
I couldn't find the specific article here, but thankfully I (sorta) remembered this guy's location (one of my drivers lives not far from the repairer) and done a web search. Try this link
Best of luck!!
Digital:
Flash:
Film:
http://www.flickr.com/photos/daveholmesphotos/
when you remove the front, there are 3 small grubcrews that grip
the focusing ring. It sounds like they have worked loose and
just need tightening...... should only take about 10 mins.
http://www.alan49.x10.mx/index.htm
lens just the beauty ring needs removing to access them.
The A Series doesn't have a beauty ring so the front
might be held by grubsrews into the body.
http://retinarescue.com/pentax50mmf1.4.html
Stuart..
AKA Welshwizard/PWynneJ
Asahi Photo in Brentford are good too. He's serviced my Z-1s...
I never even knew this place existed!
It's not too far from where I live too!!
This is a Takumar, but you can see the 3 screws. On this
I think the A35 F2.8 is similar to the A50 F1.7. The plain plastic ring that sits between the front element and the filter ring can be removed to reveal the three screws that have most likely worked loose.
Regards - Steve
How does one remove this 'beauty ring' without damaging the glass then?
Digital:
Flash:
Film:
Thank you all!!
Digital:
Flash:
Film:
Nevermind... Link shows me!!! Sorry!!
Thank you all!!
Pentax K5D, Pentax 16-45mm f4 DA ED AL, Pentax 55-300mm ED, Pentax 100mm Macro f2.8 D-FA, Tamron 28-200mm, Sigma 170-500mm.
I have just rejoined after a short period offline.
As regards Harrow Technical I have used them twice and i have been very impressed with their service.
I have sent two lens for repair, the first was my Pentax 100mm f3.5 AF Macro lens when the aperture got stuck somehow. I think something happened when I tried attaching it to a cheap set of manual extension rings. Anyway they managed to sort the problem and I have not had anything happen to the lens since.
The other lens i had repaired was my 400mm MF Sigma lens. One of the internal elements was totally covered in little tiny dots (a fungus) so every photo i took with it appeared blurred. they stripped it down chemically cleaned the lens element and now its fully functional.
So I have no hesitation in recommending them myself. I have not used anyone else so can't comment for other companies.
DaveHolmes
Member
Bradford
The glass is nice and clean... No fungus... Aperture is snappy... But it won't focus... At all...
Feels like the focus ring is un-connected... Loose.. Slack... Not right...
Thinking Harrow Technical are my best bet... Hopefully won't cost more than £50 to repair...
Anybody used them on a similar repair?
Is it even worth it, or should I just bin the lens?
Is there another lens repair place I should check out?
Advance thanks
Dave
Digital:
Flash:
Film:
