Another Waterfall from Hareshaw Linn
Posted 06/05/2014 - 19:13
Immaculate composition
Posted 06/05/2014 - 19:16
That's a great start then Stan, both the taking of the shot and processing It all looks very natural, good exposure (the brightest part of the water is the white-point), and you've kept detail on all the rocks apart from the darkest shadow areas which don't matter.
I'd probably crop a bit off the top and the RH side, just to tighten it up. Processing -wise, well I can't think of anything to say ... and I usually can!
Posted 06/05/2014 - 19:39
I'll go along with those comments - great compo AND good PP.That's a great start then Stan, both the taking of the shot and processing It all looks very natural, good exposure (the brightest part of the water is the white-point), and you've kept detail on all the rocks apart from the darkest shadow areas which don't matter.
However, I think I'll disagree with Nigel on this occasion as regards the cropping ? I can see why the right side is left there to include the side fall.
Good work
Posted 06/05/2014 - 19:46
Oh come on I guess thats a good point, its a little bit of extra interest over there on the right, but does it add much? I feel the whole thing would be stronger if the bulk of the main falls was more off-centre, and the upper parts just pull the eye up needlessly ....
Posted 06/05/2014 - 19:57
Nice processing Stan. I was going to agree with Nigel re the secondary fall on the RH side, thinking it weakened the composition.
However I then scrolled the page to crop out the rock right in the front middle, and I now think its this that weakens it. I don't know if it splits the image in two. Without it the rocks that now form the foreground give a lead in to the RH side.
Then again I could be talking rubbish
Posted 06/05/2014 - 20:02
Alan, that was lucky you didn't jump in agreeing with me too quickly I like it also without the very front rock, but that does then unbalance the top edge with a lot of foliage there. Would changing the aspect ratio to wider (by trimming top & bottom) be the ideal solution?
Posted 06/05/2014 - 21:16
OK, Nigel - I give in ! THIS version certainly appears more of an artistic composition. There is nothing to distract the eye from the main feature.
However, I liked the original for it's true record of what the falls looked like !
Whatever, good work, Stan
Posted 06/05/2014 - 21:24
I'm sure there are other ways of showing both parts of the falls - maybe a straighter-on viewpoint? I'm sure Stan will be able to experiment on a further visit. Or would it work simply as a wider panorama shape, keeping the right side but just less top and the bottom as in this new version?
Its a testimony to the shot that it can take such adjustments!
Posted 06/05/2014 - 23:44
I think there's great value in the wider-view 'sense of place' type shots within a series, so thanks for showing that for those of us who don't know the spot.
Posted 07/05/2014 - 09:08
Thanks Nigel.I think there's great value in the wider-view 'sense of place' type shots within a series, so thanks for showing that for those of us who don't know the spot.
I'm sure there are some good shots to be had. The path is about two miles from end to end and can be heavy going in places depending on fitness etc. In my mind I can see shots I perhaps should have taken and others I should have made a bit better job of. hindsight is a wonderful thing and were I to go back it would be earlier in the day, mid-week, and spend a little longer at possible sites. Definitely not forgetting the Cream Tea at the end in the Carriages Tea Room, something to look forward to
Northumberland
Stan
