AmazonBasics NiMH Precharged Rechargeable Batteries
I'd never heard of the range, so I'll have a look out of interest.
However I used to use Vapex
http://www.ebay.co.uk/itm/8-x-AA-2500mAh-low-self-discharge-Rechargeable-batteri...
Always worked fine and in tests they come out respectably
I've more recently used Panasonic which may or may NOT be rebadged enloops depending on which forums you read.
http://www.ebay.co.uk/itm/12-x-Panasonic-AA-INFINIUM-Rechargeable-Battery-2100mA...
Again I've seen respectable test reviews.
Enloops also have a new X version with increased capacity but you pay more. http://www.batterystation.co.uk/Sanyo-Eneloop-XX-Rechargeable-AA-Batteries-2500-...
http://www.nitecore.co.uk/Shop/Products/Batteries-AND-Chargers/12347-Nitecore-In...
Available on ebay too under different branded names.
12V and Mains, simple LED indicator and it works well.
http://www.candlepowerforums.com/vb/showthread.php?336936-Sysmax-Nitecore-Jetbea...
http://www.candlepowerforums.com/vb/showthread.php?352459
Also don't forget a decent charger to get the charge into the cell without degrading the cell.
Decent charger is not a problem Doug, I've used an Ansmann Energy8 with my Eneloops and 7Dayshop rechargeables with no problems so far.
I'll probably stick to Eneloops for now.
as good as the MIJ ones that you used to be able to buy.
I've still got some Panasonic NiCads from 1992 which still
hold about 1620 mAh (stamped 2000 mAh) I use them in cameras
and flashguns without any problems.
Sanyo Eneloops are about the best today.
Concert photography
Totana,
Spain.
How do they compare to the standard Sanyo Eneloops.
