Air Tattoo RAF Fairford - Sigma 10-20???
Posted 10/06/2014 - 14:15
In a situation like that - especially where there are large crowds - you will probably find the 18-135 is not "wide enough" and you will need the 10-20 (I always take mine with that in mind, and it usually does get used).
W.r.t the 55-300, practice some panning shots beforehand, and get used to focusing it manually as the autofocus is rather too slow - especially for fast jets (and I would not bother with fast approaching aircraft unless you can sort out the manual focusing - even the bigger Sigmas have problems with that on Pentax bodies )
Posted 10/06/2014 - 14:19
I took my 12-24mm Sigma to Yeovilton last year for the static displays and found it just right for getting shots of the aircraft and cars that were on the ground. It really does help to have as wide as possible when there are large crowds of people.
Yeovilton Static Display by Mike.Pursey, on Flickr
Posted 10/06/2014 - 14:23
Thanks John
Thanks for the great shots Mike no problems with too much sky and concrete there.
I'm hoping the F-35 will hover for a bit so I won't need to be that fast practice some panning shots beforehand
Posted 10/06/2014 - 17:31
Wow that's got to be some responsibility working on a Jet Fighter's software. It could be a little more problematic than a camera lockup
Sometimes I'm serious and sometimes not, but I consider sarcasm an artform. Which is it today?
Posted 10/06/2014 - 18:00
Its pretty mundane software to write, lots of restrictions and testing it to death, when problems make it to the aircraft they are usually because the requirements were wrong (but I would say that :lolWow that's got to be some responsibility working on a Jet Fighter's software. It could be a little more problematic than a camera lockup
Having said that when it takes off at Fairford I'll be the one wearing a hard hat.
Posted 10/06/2014 - 18:12
Haha and at least your there to tell them to switch it off and back on again
Posted 11/06/2014 - 08:40
10-20 Sigma will be great, you should be able to get all of most of the Jets in the frame, the added bonus is you can take shots much closer up so other spectators shouldn't pose so much of a problem for you as to those with longer lenses.
Take the 10-20, I'd also probably take a 70-200, and maybe my 300 & the tele-converter for the added reach it will bring...
A few bits & Bobs
Posted 11/06/2014 - 11:18
No just switch it off. Done
Posted 11/06/2014 - 12:14
Thanks Andy
I've only got the 55-300 to play with, probably won't have much time to shoot the flying with my son with me anyway.I'd also probably take a 70-200, and maybe my 300 & the tele-converter for the added reach it will bring...
If I were flying it I wouldn't even do that, I'd have long since ejected
Westhoughton,
UK
Cheers Steve
