AF Adjustment
Posted 10/02/2014 - 10:02
MikeP I too have not been over the moon with my DA* 16-50mm, time for some adjustment trials I think.
Fletcher8
Fletcher8
Fletcher8.
Posted 10/02/2014 - 11:31
Any reason why the exposure seems brighter on the corrected picture?
Sometimes I'm serious and sometimes not, but I consider sarcasm an artform. Which is it today?
Posted 10/02/2014 - 13:25
Nope, I noticed that as well.Any reason why the exposure seems brighter on the corrected picture?
TAv mode - Same shutter speed/aperture/focal length .. did notice the auto ISO jumped from 800 to 1100 though so that's probably the reason.
Edit: These weren't processed in any way, just straight Raw to Jpeg conversion.
Posted 10/02/2014 - 14:02
I wasn't overawed by mine either. One SDM failure, a trip to JPS and it's now awesome.
Now let down by operator incompetence
AKA Welshwizard/PWynneJ
Posted 10/02/2014 - 15:26
This is exactly the sort of post that makes the mind boggle that AF adjustment on a per-lens basis was not included as a matter of course on all camera models since the inception of DSLR photography.
This coming from a K200D owner, with AF adjustment only as a global setting and having to hack the camera just to get to that...
I hope you enjoy your newly-discovered lens, Mike.
Posted 10/02/2014 - 17:26
And it would be so simple to make this self-calibrating - focus in contrast detect, switch to phase detect without changing focus, read and store the phase detect offset ...
Posted 10/02/2014 - 19:33
As an aside, was there any form of focus adjustment on the K-100d?
I'm using this again whilst my K-30 is being looked at and it back focuses horribly
Edit: just googled this on the bus to work. Seems a special service menu is the only way and it's a global setting for all lenses. Might try this later on...
Posted 10/02/2014 - 21:17
Sounds like the K200D. Be careful,you could damage the camera if you fool with any other settings.
Posted 11/02/2014 - 06:12
kh1234567890 wrote:
interesting idea. I'm trying to think of a reason why this couldn't work, but can't
And it would be so simple to make this self-calibrating - focus in contrast detect, switch to phase detect without changing focus, read and store the phase detect offset ...This is exactly the sort of post that makes the mind boggle that AF adjustment on a per-lens basis was not included as a matter of course on all camera models since the inception of DSLR photography.
Posted 11/02/2014 - 07:36
Smeggypants wrote:
Agreed, me too!kh1234567890 wrote:
interesting idea. I'm trying to think of a reason why this couldn't work, but can't Jonathan-Mac wrote:
Patent that one!
Posted 11/02/2014 - 08:43
richandfleur wrote:
Agreed, me too!Smeggypants wrote:
interesting idea. I'm trying to think of a reason why this couldn't work, but can't kh1234567890 wrote:
[quote:3496ace15f="Jonathan-Mac"]This is exactly the sort of post that makes the mind boggle that AF adjustment on a per-lens basis was not included as a matter of course on all camera models since the inception of DSLR photography.
And it would be so simple to make this self-calibrating - focus in contrast detect, switch to phase detect without changing focus, read and store the phase detect offset ...[quote:3496ace15f="Jonathan-Mac"]This is exactly the sort of post that makes the mind boggle that AF adjustment on a per-lens basis was not included as a matter of course on all camera models since the inception of DSLR photography.
Patent that one![/quote]The problem I have found is that a lens can front focus at one end of its range and back focus at the other. I have experienced this with DA* 16-50, DA*50-135 and DA 16-45. It is a lesser problem on the K5 compared with the K10, but it still exists and as a result the adjustments I make are always a compromise.
So to expand on this idea I would like the option to save at least three AF adjustments per lens.
Regards - Steve
Posted 11/02/2014 - 09:21
I think Sony or Olympus have multiple focus points per lens as well. And of course the Sigma dock allows you to do it, except they don't make the dock for pentax fit lenses.
Posted 11/02/2014 - 09:44
Regards - Steve
yes I'd go along with that.So to expand on this idea I would like the option to save at least three AF adjustments per lens.
Regards - Steve
Currently I adjust mine with a bias to the near field as that's where the biggest inaccuracies occur in my experience. but yes it is a compromise.
Hythe,
Hampshire UK
Anyway, the other day I decided to get it out again and this time I did some AF microadjustment ... this is the results with +5
Without adjustment
[IMG]http://img.photobucket.com/albums/v188/Sockpuppetuk/IMGP0142_zps6aab7768.jpg[/IMG]
With adjustment
[IMG]http://img.photobucket.com/albums/v188/Sockpuppetuk/IMGP0144_zps276f6e44.jpg[/IMG]
Now 100% crops
[IMG]http://img.photobucket.com/albums/v188/Sockpuppetuk/IMGP0142_cr_zpsdabeeada.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v188/Sockpuppetuk/IMGP0144_cr_zpse7ff46b3.jpg[/IMG]
I suppose the point of this post is just to say anyone who has not done any adjustment of your lenses then try it, you may be surprised by the results.
