AF adjustment - finally an answer!
nathanever82
Posted 24/04/2010 - 09:33 Link
Finally somebody tested the option of hacking into the k7/k20 system, and adjust the af - resulting in a cumulative adjustment also for the in-camera af adjust measure.
this is the dpreview thread:
http://forums.dpreview.com/forums/readflat.asp?forum=1036&thread=34974010&page=1
I've asked the very same question about a year ago when I wanted to change my af on my lenses, and Im very pleased I now know its possible, and effective.
(Remember that it only works if all your lenses front/back focus by a certain margin; If they vary in the +/- then a hacked af adjustment will completely throw off one of the lenses.)
Kind regards to all,
Nathan
'Between the lights there is always a shadow'
www.nathanservi.com & PPG
JohnX
Posted 24/04/2010 - 11:09 Link
So, what did your MODSET contain in order to make the 'global' adjustment?
nathanever82
Posted 24/04/2010 - 11:14 Link
Oh, i haven't done it yet, nor have looked at the hack properly - I was just reporting another user's success!
JohnX
Posted 24/04/2010 - 11:17 Link
Ah! Ok, thanks!
terje-l
Posted 24/04/2010 - 20:08 Link
MODSET.442 is for K20D v. 1.03
MODSET.474 is for K7 v.1.01
The file should contain one line of text, followed by a line shift:
[OPEN_DEBUG_MENU]
Holding the Menu button while switching the camera on gives access to a menu where you may ENable or DISable the DEBUG menu.
I've tried it on my K20D, and it works. As far as I can see, the Debug adjustment provides a global setting, while the normal focus adjustment is performed on tp of this global adjustment (cumulative).
All normal disclaimers apply
See also this link
(edit for typo plus link addendum)
Terry
Edited by terje-l: 24/04/2010 - 20:11
