Advice re sensor cleaning function
Posted 08/08/2013 - 15:10
The K-5 mechanism is ultrasonic, so you won't hear it.
Posted 08/08/2013 - 15:12
Many thanks John
Posted 08/08/2013 - 16:49
I need to go to the next stage and do a sensor clean with a swap....gulp!
Have two marks that will not budge with the built in shake.
Posted 08/08/2013 - 17:01
Me too....just keep cloning them out in PSE at the moment....
Russ,
Don't worry,
Just make sure you only wipe the sensor ONCE in each direction (that is: from left to right, then right to left, using each side of the swab only once) and you'll be fine.
I had a group of dust spots on my Kx which would not budge, until I used the swab....now ....clean as a whistle!, and has been ever since.
Don't worry,
Regards,
Michael
Michael
Posted 08/08/2013 - 17:52
I tend to use an Artic Butterfly, generally removes the need for a wet wash and tbh only need to us it 3 or 4 times a year, and I prob shoot over 500 frames a month on average.
Chris
Posted 08/08/2013 - 19:59
Me too....just keep cloning them out in PSE at the moment....I need to go to the next stage and do a sensor clean with a swap....gulp!
michaelblue wrote:
Russ,
Don't worry,
Thanks for the encouragement. I have the swabs ready to go. Russ,
Don't worry,
Artic Butterfly...sounds interesting, google time.
Posted 08/08/2013 - 20:46
I had to regularly wet clean my K10D and K20D sensors, which had the Low frequency sensor cleaner.
The k-5 usingthe ultrasonic HF cleaning I've never had to clean either K-5s sensor for over 2 years since I've had them. Impressed
Posted 09/08/2013 - 06:31
Same here
Posted 09/08/2013 - 12:36
Just had my K30 sensor cleaned I parted with hard earned cash as I have learned from experience that I am a ham fisted oaf.
A very happily using a K30. My wife says I have too many lenses.
Posted 09/08/2013 - 13:12
I did that in 2009 with my K10D. Paid up £25, the guy popped out the back with my camera and 2 mins later reappeared with it done. An hourly rate of approx £750.....
Posted 09/08/2013 - 21:48
You could buy the Pentax O-ICK1 sensor cleaning kit. I find it works well when a blower doesn't shift it.
I find with my K5 the sensor needs a clean every year or so.
Posted 09/08/2013 - 22:12
Another vote for the Artic Butterfly. It has not let me down so far
Barrie - Too Old To Die Young
13 years
Kirknewton,
Scotland
I have 2 Pentax bodies:
When I run the sensor cleaning function from the menu settings....
Kx - vibrates quite loudly and I can feel things shaking!
K5 - nothing happens.... no noise and no vibration.
Question is, is this how it should work on the K5?
Appreciate any advice
thanks
Sam
