Advice on Pentax 67 + lens
Posted 14/05/2013 - 14:53
If it works, I think that it's a bargain at that price. Sorry I can't help with how to open the back or the battery compartment, but I suggest you look for an online copy of the manual.
Posted 14/05/2013 - 16:28
The Pentax 67 went through three different major version upgrades: Pentax 6x7 (1969), Pentax 67 (1989) and the Pentax 67II in 1998. The earliest version, the 6x7 model started out without MLU, but this was included in the later 6x7 models. The 67 differs from the first model in this way:
"In 1989, the Pentax 6x7 underwent some other upgrades, most significantly the shutter timing was changed from being partly mechanically to being fully electromechanically controlled. This helped improve exposure accuracy (unfortunately it also meant that the bulb-mode required batteries, which disappointed many astrophotographers; you can get Pentax to modify your camera to not require batteries in bulb). Some components of the all-metax 6x7 were replaced with polycarbonate to lighten it. The upgraded model was renamed the Pentax 67." http://www.photoethnography.com/ClassicCameras/AsahiPentax67.html
It is difficult to say much about the condition of the camera you have been looking at, but I guess one could find out by examining the camera carefully, if it has seen much use or been mistreated. I believe for instance that the film forwarding mechanism is a weak spot on these cameras. You should also check the locking system for the prism housing, it is important that this is not damaged. The light seals on a camera from 1989-1998 could possibly still be okay...?
GBP 170 seems like a very low price for the Pentax 67 + 105mm. Take a look at prices at ffordes and KEH, they usually go for much more than that.
I am a happy owner of a Pentax 67ii system, and my best advice is: Go for it
Good luck!
Bjørn
Good luck!
Bjørn
Posted 14/05/2013 - 18:33
I would say that is NOT too cheap for a camera with a 'dent in the prism'and flat battery -- don;t forget in Doha there probably is no 20% VAT tax in cameras as in UK .
Posted 14/05/2013 - 20:54
Take a look at this as a comparison: http://ffordes.co.uk/product/13051016263681I would say that is NOT too cheap for a camera with a 'dent in the prism'and flat battery -- don;t forget in Doha there probably is no 20% VAT tax in cameras as in UK .
Bjørn
Here,
there,
everywhere
Any advice on whether it's worth buying amd what to check on it would be much appreciated.
My Website
flickr
G+
Facebook
