adaptall 2 fitting
steve42
Posted 25/09/2009 - 20:50 Link
hi all ive got a tamron lens the adaptall 2 fitting at the moment its got the pk adapter on will the pka adapter work if so what modes will work, im using a gx10.
steve
grahamwalton
Posted 25/09/2009 - 21:05 Link
A Tamron PKA adaptor should work fine with your lens. With the PKA adaptor fitted,if you set the Tamron Lens to the A setting, then your should be able use all modes, just as if you were using a Pentax A manual lens. Unfortunately you will not get autofocus.
Tamron PKA adaptors tend to be more expensive than PK.
Friendly Regards
Graham
steve42
Posted 25/09/2009 - 21:17 Link
hi graham have looked at my lens cant see the a setting you mention is it onthe lens or the pka adaptor
steve
Mike-P
Posted 25/09/2009 - 21:32 Link
On the Adaptall lenses you need to move it to the AE setting (on the lens) if you are using the PK/A mount
steve42
Posted 25/09/2009 - 21:49 Link
cheers mike when it on will all modes work on the camera.
Mike-P
Posted 25/09/2009 - 22:03 Link
With the PK/A mount you will get auto aperture and metering on all camera modes.
