*istD banding
Posted 21/02/2006 - 07:53
The only level I would accept is none. If it were an insurmountable design defect I guess some subjects would go back to film.
Is there a problem, *istD Users? :
Posted 21/02/2006 - 09:55
Ouch! Definitely not the type of 'flaw' one only picks up on by zooming in on the image. No suggestions from my quarter though but a note of empathy!
Posted 21/02/2006 - 11:36
Doesn't look right at all.
I regularly take images at ISO1600 and ISO3200 with the *ist-D and have never had any perceivable banding.
If your RAW image was correctly exposed (ie you're not trying to pull out deep shadows from an underexposed image), then I'd say it's a repair job - quite likely a CCD problem.
Posted 21/02/2006 - 11:53
Matt,
If by correctly exposed you mean no post-processing, that is what the image is. Ie a night-time, moonlit shot converted from RSP with no additional tweaks - just some sharpening
Looks like I ought to send it back - got about 10days left on warranty!
Andy
Andy
Posted 21/02/2006 - 13:12
What I meant was whether you were having to ramp up the exposure compensation in the RAW convertor.
For instance, in Capture One, there is the "EC" control (Exposure Compensation). If you've set that to +1, +2, or even +2.5 then you will get a serious amount of "grunge".
For instance, I took a 10s shot with the lens cap on at f22, ISO1600. There is some background noise at EC+0, but set EC+2.5 and I can see some kind of banding amidst all the terrible CCD noise.
With a RAW file, the shadows have noise. The further into the shadows you go, the more noise. So, 1stop under will be noisy, but 2stops under will be twice as noisy. That's one of the reasons people say "Expose To The Right" when shooting RAW (because CCDs have a linear response, whereas film and our eyes are logarithmic).
Another question to ask is: has this always happened?
Posted 21/02/2006 - 13:23
Not sure - but suspect it has. I remember a few shots taken several months ago where I think banding occurred.Another question to ask is: has this always happened?
A thought - re another thread and batteries/ battery grip etc and the use of Ni-MH batteries - could it be a low voltage problem causing internal supply around the sensor to 'wobble' a bit? The banding is not fixed - ie on the previous shot to the one posted the bands are in a different position to this
Andy
Posted 21/02/2006 - 14:04
It's more likely to be temperature related. CCDs are not very good for long exposures. CMOS sensors are much better since they have a much lower operating current.
The noise will increase with the temperature, therefore the longer you have the camera running, the more noise (and possibly banding) will occur. Banding does occur (in CMOS sensors too), and Capture One has a banding suppression that can help.
The other thing is that the higher the ISO, the more significant the noise becomes.
Also, watch out for devices nearby that emit EMI (such as mobile phones). It is possible for these to affect the CCD, especially when using long exposure/high ISO settings.
To be honest, I've never really tried long exposures at high ISO, though I wouldn't have expected much at ISO400... I'll see if I get a chance to take some long test shots to compare.
(You could email the RAW if you want. Shove it through Adobe DNG convertor to shrink it first though!)
Posted 21/02/2006 - 22:31
Matt,
I don't have the Adobe DNG converter - is it compatible with Elements 2? or can it stand alone?
Andy
Ps I wasn't near any EMI stuff - just on a beach with nearest street lamps about 150metres away - unless the guy fishing had something txing!
Andy
Posted 22/02/2006 - 05:55
Posted 22/02/2006 - 09:34
Thanks, Matt.
File has been e-mailed to you
Andy
Andy
21 years
North Devon
Also at iso1600 2secs - awful! the picture is pretty well striped. The banding is horizontal.
Any insights etc welcome
Andy
