*istD and tamron PKA adaptall mounts
Posted 09/06/2005 - 18:05
Hi Stevo,
I have one of those adpaters as well. It seems it will only work in Manual metering mode. And even then, you have to press the 'green' button near the shutter release to operate the meter. This does mean that if the light changes significantly before you take the picture, exposure will be slightly out.
Hope this helps
Andy
Hope this helps
Andy
Posted 02/07/2005 - 05:20
Hello Stevo,
I have been using an older Tamron SP 90mm F2.5 macro lens with an adaptall "KA" mount without any problems. I kept it in AE(?) position and the *ist-D metered fine in Av, Tv, and M modes, and I could override Aperture or Shutter speed with the thumbwheels. It acted like any other Pentax "A" lens.
Regards,
ducerman
Regards,
ducerman
has anyone here used tamron adaptall lenses with PKA mounts successfully on the istD? I got a KA mount on ebay, and yes it does have electrical contacts (three of them, like old KA lenses), but my istD doesn't want to talk to it. Any ideas, or is it just not going to work? Unfortunately, I don't have another suitable body to try the mount on at the moment.
http://www.siblingmedia.com/
http://www.siblog.co.uk/
Posted 02/07/2005 - 11:30
Thanks ducerman,
It was my Tamron SP 90mm F2.5 macro I was trying to use with the KA mount, but I'd given up on it. Maybe I've just got a duff mount (was ebay after all)
Which firmware version are you using with your istD?
thanks again,
thanks again,
Posted 02/07/2005 - 11:55
Steve,
I am using Version 1.10.
The lens and mount I was using were borrowed from work.
I will check the instruction sheet for the exact adapter model.
I just purchased a used FA100/2.8 Macro and will be giving it a workout this weekend. (from ebay-same as 90% of my Pentax gear. I purchased the *ist-D, kit lens, flash and grip at a local camera store.)
Regards,
ducerman
Regards,
ducerman
Thanks ducerman,
thanks again,
Thanks ducerman,
thanks again,
Posted 06/07/2005 - 17:28
The mount on the lens was an "Adaptall-2 Custom Mount for Pentax KA".
The instruction sheet states "only for use on Pentax A-series cameras".
There is another mount for Ricoh XR-P, which can be used with other "K" mount cameras
Regards,
Ducerman
Regards,
Ducerman
Steve,
Regards,
ducerman
Steve,
Regards,
ducerman
stevo wrote:
Thanks ducerman,
thanks again,
Thanks ducerman,
thanks again,
24 years
