*ist DL DOF preview
Posted 18/04/2007 - 06:35
Depth of field preview allows you to see how much will be in focus, and what happens to bright highlights.
It has to stop the lens down to the aperture you have programmed to use (or the camera has chosen) - that's why the view finder goes dark. The camera turns off the lights so you can concentrate on the view
It's easier to use "Av" mode where you can choose the aperture. If you choose f/22 and use the preview it will go very dark indeed. As you get nearer to wide open (f/4 etc) then the view becomes progressively brighter (because the aperture blades are letting more light in).
It takes a bit of getting used to, but this is the DOF preview used in all SLR cameras since the year dot! (The K10D adds an LCD preview function as well as optical view finder preview.)
Hope that helps!
Hope that helps!
Posted 18/04/2007 - 10:08
Ok so now to sound stupid
I see why it gets dark but how do you use it. What am I looking for?
Thanks for answering
Posted 18/04/2007 - 10:37
Depth of Field is a "zone" of what will be in focus depending on the aperture that is set.
A small aperture (high number) will increase DOF while a bigger aperture (small number) will reduce it.
Example;
If you focus on a subject ten feet away and use an aperture of say f4 then not all of the scene will be in focus, much of the near forground and pretty much most of the background will be out of focus, however if you "stop the lens down" ie use a smaller aperture, say f16, then the amount of the scene that will be in focus will increase. this allows you to use the aperture for creative effect, ie throwing backgrounds out of focus for portraits or ensuring everything is sharp for landscapes.
DOF also applies to the human eye, have you ever noticed how things seem much sharper when you squint your eyes?
Example;
Posted 18/04/2007 - 10:49
Frankly, trying to determine what is in focus through a darkened viewfinder is very difficult. This is a feature I never use. On a DSLR it is better, if you have the time, to take a couple of pictures at different apertures and then zoom in to see what they look like.
I suspect a majority of photographers never use DOF preview. It's one of those things that reviewers crtiticise a camera for not having, but for many of us it's a complete waste of time.
Posted 18/04/2007 - 12:50
I suspect a majority of photographers never use DOF preview...
Close. I can think of two occasions I suspect a majority of photographers never use DOF preview...
I've used it when doing macro shots where there are highlights behind. The DOF preview helps you to see what blooming and bokeh there'll be from the background.
But yes, taking a shot and previewing on the LCD is a million times easier and more accurate too
Posted 18/04/2007 - 14:18
I'm with Matt
When I bought my first Pentax (the MZ7) I thought I wouldn't need it, how wrong I was, I kept wishing I'd kept my OM30, I was so frustrated I bought the MZ5n as a second body but the MZ7 soon became that
Matts hit the nail on the head, DOF preview is invaluable in macro work, its also handy when you have very near forground elements in landscape photography.
Posted 18/04/2007 - 18:50
Thank you all for your posts.
I already know what DOF is and how to achive it. I was just confused as to what the DOF preview was and what it did for you. I played with it for quite some time and could not find any benifit. I did not see how it was helping me to determine DOF. For that reason I thought I was using it wrong. I will try it with macro work to see what happens.
Thanks again everyone. It is so nice to know that this community is here to help. I hope I can be helping soon!
Posted 19/04/2007 - 14:13
For some of us its crucial, along with depth of field table and scales!I suspect a majority of photographers never use DOF preview. It's one of those things that reviewers crtiticise a camera for not having, but for many of us it's a complete waste of time.
I have read the manual and searched Google as well as this forum for this answer with no success. I suppose because the answer is supper easy and I am the only one struggling with it.
I cannot figure out what the DOF preview does. The manual says that you can focus on your subject and use the DOF preview to check your DOF in the viewfinder. All my view finder does is darken a little and the numbers on the display at the bottom disappear. What is suppose to happen?
Am I missing something here?
