"A" setting with Adaptall ll lenses
Posted 22/12/2012 - 14:54 - Helpful Comment
Hello Barrie
link
I have the 52B and 18F with PKA adapter and seems to work fine on lens AE position and Av on the camera. The camera indicates f2.4/2.5 on the widest setting.
Not found any issue with the order of assembly as long as you check operation of the aperture before connecting to the camera.
Hope this helps
Bill
link
Hope this helps
Bill
Posted 22/12/2012 - 15:31 - Helpful Comment
Hi Barrie
Do not know if this helps but i have an sp90mm 72b with a PKA adaptor that works just fine with a kenko tele converter in AE setting.
Posted 22/12/2012 - 16:48
Thank you gentlemen. It would appear yesterday I did not have the lens and tube connected correctly. After seeing your posts and knowing it should work, I've had another try and hey presto, it works.
Barrie - Too Old To Die Young
Co. Durham UK
