X sync socket problem
Posted 12/02/2010 - 20:34
John,
AKAIK, Canon are easily popped. Apparently trigger voltages over 8V (IIRC) will blow the trigger mechanism.
They've probably just got a straight transistor output.
It's a tricky one - but easily fixed with the booster.
Posted 13/02/2010 - 10:30
Yes, I reckon that the Canon is a simple transistor output and therefore likely to be more fragile than the Pentax thyristor system.
I remember a post from Clarky stating that he uses high voltage flashguns on his K20D with no problem. I have not plucked up the courage to try it yet, especially as this contradicts the advice given at SRS when I bought my K10D. However I now believe that the Pentax system is likely to be OK up to 300 volts or so, the usual minimum voltage that thyristors are rated at. When I am feeling braver I will try it out.
I just wish Pentax would tell us straight about this. Mind you I suppose they have nice new low voltage trigger flashguns to sell so they do not want us using our old kit instead
I am on the hunt now for some other brand cameras to test to see how they do it!
John
Posted 13/02/2010 - 15:06
Don't know if this is completely relevant but?
I was trying to use a set of old Courtenay Solaflash units a few days ago with a PC sync cord connection to my K7. Immediately I plugged in the cord the flashes fired but they would NOT fire when I tripped the shutter.
After some research on the net, it seems the Courtenays may have a negative centre pin and this apparently can cause the problem. I've just now tested the K7 using a sync cord connection to my Metz 48 AF-1 and it works fine so it looks like there was no damage to the camera from the reversed polarity.
Posted 28/02/2010 - 11:00
Useful discussion, I'm just trying to understand this myself.
So bottom line (albeit very simplistic), if I'm acquiring a flash that requires triggering through the PC sync, there are likely to be issues?
I'm looking at buying a Paffrath & Kemper Ring-flash
Posted 19/01/2012 - 11:42
Apologies for resurrecting this very old thread but I also have been looking for a way of safely using my K5 sync socket with a Courtenay Solaflash without frying the electrics.
I came across this little gadget which seems just the job
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160715596293&category=30087...
Has anyone got one of these and does it work o.k.?
Regards, Philip
Posted 22/01/2012 - 23:03
Well, I have purchased the 'Sync Protector' and it works fine. An easy solution for anyone with old studio lights.
Regards, Philip
22 years
Dorking,
UK
I am now intrigued as to how the other camera manufacturers arrange their flash interfaces and whether this arrangement that latches is unique to Pentax, I have already determined that Canon are different and do not latch. I must try to borrow some other cameras to test, the problem being that I only know Pentax owners (my 2 colleagues at work who own digital SLRs are fellow Pentaxians). I cannot imagine that latching is the norm as if this were the case then these trigger manufacturers would surely have it gripped?
(Edit: Punctuation error)
