Wireless TTL with Nikon Flashes!
Flagship P9 and versatile P7 expand Samsung's portable SSD lineup with USB4 connectivity. Doubled performance at 4,000MB/s supports demanding workflows including 12K direct recording.
Some pre-DSLRs Nikon SB flashes indeed offer an (AFAIK) unique slave mode called SU-4 (named after the little separate unit that can also transform non-SU-4 flashes into TTL wireless slaves).
In this mode, the slave flash not only detects when the main flash is fired, but also when it is cut off by the camera, and so reacts accordingly and shut off its own burst.
Yeah, that's right : Nikon really made an universal TTL wireless slave flash, back in the film days...
Best part is that the last crop of Nikon film flashes featuring this are simply useless on Nikon's DSLRs, so they can be found for next to nothing, and are in really good shape...
The SB-50dx, for instance, has this ability and can be easily found for 50€... So has the SB26 (IIRC), the SB-80dx, and some others...
So, if you can try this, shoot and post some sample!!!
I've borrowed a SB-800 from a friend, dusted my ZX-L (still doing 6 rolls/years), and made some tests...
Here are the results:
Pretty neat, no?
So, there is only three steps (and one is quite optional!) to set up your slave flash:
1 - power on your nikon flash, select SU-4 mode
2 - open your internal flash
3 - Optional : use a Nikon SG-3IR infrared screen in front of your internal flash so it doesn't register in the picture.
Any change in your settings (aperture, sensitivity, flash/subject distance) is automatically compensated by the SU-4 mode, as it syncs with your internal TTL flash (which cuts off its power when proper exposure is reached).
This trick can also be used with a *istD, DS or DS2, but you have to force the TTL mode by using the lens out of its A position...
Personally, I find the results very good, but a little bit too bright, so next time I'll try with a -1EV flash comp...
