Wireless Triggers for K3II/K-1
Samyang 14mm F2.8, Pentax DFA* 70-200 F2.8
They look similar to the Neewer triggers.
Lenses: Pentax D-FA 24-70mm 2.8, D-FA 15-30 2.8, D-FA 70-200 2.8*, Pentax 35mm 2.4, 50mm 1.8, 18-135mm WR, 55-300mm HD, Sigma 70-300mm (macro), Tamron 17-50mm F2.8.
Film: Mamiya C330 Medium Format, Pentax Super ME.
https://www.amazon.co.uk/Neewer-Channels-Wireless-Trigger-Receivers/dp/B008MTN9M...
You need 3 transceiver' units in order to control 2 flashes, one in Transmitter (TX) mode on the camera hotshoe, and one on each flash in Receiver (RX) mode. So not the cheapest solution, but a reliable and practical one, especially if your flashes are placed in difficult positions or you need to make frequent adjustments to power, and want to experiment with differing effects.
Or go a big step further and get the latest V6II models, and you can add remote manual High Speed Sync plus remote flash head zooming to your arsenal!
My Metz 44 AF-1 is a HSS flash head and I'd love to use that in bright daylight, off camera in a softbox for portraits.
One thing that bugs me is the Canikon shooters can shoot wirelessly in HSS with a range of battery studio heads or flashguns on location but we Pentax shooters can't
Manual HSS is a good step up in complexity over automatic HSS, more difficult to manage in a dynamic environment, because every exposure time adjustment ('shutter speed' ) requires a compensating adjustment to another parameter ...(ISO, aperture, distance). This is not the case for automatic HSS exposure (ie the Pentax proprietary system), as the flash output is automatically adjusted in that case.
So, in outdoor, dynamic fluid situations, and especially where the ambient light exposure needs adjustments, then manual HSS adds to the workload. But, the advantage of remote radio control, plus the big benefit that brings with communication reliability over high distances, may outweigh that other disadvantage.
I'd be careful to double check with Cactus, on their community forum, that your Metz flash is tested and confirmed as HSS compatible with the V6II before committing.
Stuart..
The Neewer/Cowboy/Godox triggers were £15.99 (from Amazon) and just have the centre pin but they work.
9 years
I borrowed a pair of Yongnuo YN-603C II (Canon) and they work intermittantly on both cameras, I have also been looking at he Cactus v6 trigger.
Does anyone use the Cactus or recommend an alternative?
Thank you,
