Wireless or tethered mode?
Posted 12/02/2007 - 08:58
Tethered: auto zoom operates, supports HS mode.
Wireless with popup: yes, multiple flashes are no problem (I use a 360 and 540 together). HS not supported.
One flash on body, one remote: supports HS mode.
If you're shooting outdoor portraiture, then tethered is preferable for fill in flash (because you can shoot HS). For all other uses, pop-up wireless is just fine!
(Just remember to set the flash guns to "Slave 1" mode = intelligent P-TTL slave )
Posted 12/02/2007 - 12:09
Thanks for the response Matt!
I only use off-camera flash for macro, so lack of HS is no problem for me and given the high cost of tethering, I think I'll stick to wireless
Cheers,
Reuben0
Cheers,
Reuben0
Posted 12/04/2007 - 15:25
Hey
I was onedering if anyone has been able to fire a Sigma flash wirelessly without the pop up flash going off?
Paulypentax
Paulypentax
Posted 12/04/2007 - 16:58
Whether the popup fires or not is not down to the remote flash gun
If you have the *ist-D or K10D using wireless commands, then there is a custom menu option to use the pop-up as a controller only.
If you are trying to use any of the others - you can't turn off the pop-up. You can only use flash exposure compensation to reduce the effect of the pop-up.
HTH,
HTH,
Posted 12/04/2007 - 18:56
Hey
Paulypentax
"Wireless" doesn't mean radio. The remote flash is controlled by a burst of little flashes from the RTF or body-mounted flashgun. It's a bit like Morse code on a torch, but much quicker.Hey
Paulypentax
21 years
Devon,
UK
On a related note, is it possible to control 2 360/540's using the built-in flash or will it only control 1?
Apologies if this is in the manual, but I couldn't find it
Cheers,
Reuben0
