Wireless Flash Modes
Posted 08/08/2005 - 20:37
Contrast control involves the use of the flash on the camera plus a separate flash triggered by the first.
A slave flash is one that is triggered by another. It must therefore have a sensor of some kind.
A master is the flash that triggers the slave flash. It is usually the camera flash, or a flash mounted on, or connected by cable to, the camera.
High speed sync involves a number of separate but very rapid bursts of light which coincide with various positions of the shutter, so that even at high shutter speeds (when the film/sensor is never completely exposed to the light at one time) a sufficient amount of light reaches all parts of the film/sensor.
It can, for instance, be used for fill-in flash on a bright day when you want to use a shutter speed higher than the sync speed.
The only Pentax flash that provides all these facilities is the AF360FGZ, and it will only work on its own as a slave flash with the *ist D. If you want to use it as a slave flash with the DS or (I think) DL, you will need to mount another 360 on the camera. Not a cheap option.
Posted 09/08/2005 - 01:19
Thanks George I appreciate your help and the many other insights you have provided on this forum!
I'm still confused a little though....Is contrast control flash and slave flash essentially the same thing?
Or by contrast control are they only referring to the pop-up triggering a single slave? What's the difference between that and slave mode? (Multiple flashes, use of the hot shoe?)
I own a *-ist D and the AF360FGZ and also an AF330FTZ. I am trying to figure out how to use them together and understand flash better.
Posted 09/08/2005 - 09:22
"Contrast control" is Pentax's fancy name for using two flashes, and yes it will necessitate a master and slave set-up.
The power ratio between the two flashes is set at 1:2 (RTF:slave).
Effectively the slave unit will provide the bulk of the light, and the RTF (retractable flash, AKA built-in flash) will provide the fill. If you have two 360s, you can use one of them on the camera instead of the RTF. If you have a DS or DL you will need two 360s, because the RTF won't trigger the slave.
Incidentally, when I said that the 360 will only work fully on a *ist D, I was referring to the DSLRs. As far as I know, it operates in exactly the same way on the MZ-S as on the D.
The 360 is a wonderful flashgun, but apart from HSS it doesn't actually do anything that can't be done manually, with a variable output flashgun and a cheap slave trigger. And you can take a lot of pictures in the time it takes to read the operating manual!
22 years
Pottstown PA USA
I understand the contrast control...the slave mode has me confused.
Can the AF360FGZ be used wireless without the built in flash?
Also when would high speed sync mode be used?
