Wide Angle lens choice?
Posted 09/04/2012 - 14:08
I have very good results with my Pentax DA 14. It does open to 2.8, but it is kind of bulky. If the bulkiness isn't a problem for you, then it should do the job for you.
Posted 09/04/2012 - 14:35
StarScr33m wrote:
I'm looking for one which has at least some range e.g. 10-20mm or something similar. It needs to be at least f2.8 continuous...
Sorry to be the bearer of bad news, but you won't find an ultra-wide zoom with a max aperture of f/2.8 continuous. It doesn't exist (at least not in Pentax K-mount fit). The closest you are going to get is the Sigma 10-20mm f/3.5. If f/2.8 or better is the most important thing for you, you are going to have to settle for a prime, and even then your choice will be extremely limited. There is a Pentax 14mm and a Sigma 15mm which fit the bill, and I think that's about it.I'm looking for one which has at least some range e.g. 10-20mm or something similar. It needs to be at least f2.8 continuous...
As far as low-light performance goes, have you tried pushing your ISO up a little higher? I believe the K-r performs quite well in this respect. It should certainly be adequate for restaurant lighting.
Look at it this way, the difference between f/3.5 and f/2.8 is only two thirds of a stop. Pushing your ISO two thirds of a stop higher should really not present a huge problem.
Posted 09/04/2012 - 18:07
Another approach would be to try different types of noise reduction software. I don't tend to take photos in low light, so my experience doesn't go beyond Silkypix, but others might have some suggestions.
Posted 09/04/2012 - 19:53
Pentaxophile wrote:
There is also a Samyang 14mm f2.8 which is reportedly excellent. But f4 should be fine, if you bump the ISO up, and that would open up plenty of options.
Although Samyang only make manual focus lenses at this point...There is also a Samyang 14mm f2.8 which is reportedly excellent. But f4 should be fine, if you bump the ISO up, and that would open up plenty of options.
I'd bite the bullet and raise the ISO personally... That or a shiny new flashgun (on a wireless trigger, strategically placed...)
Digital:
Flash:
Film:
Digital:
Flash:
Film:
Posted 09/04/2012 - 20:36
StarScr33m wrote:
....my 18mm at f3.5 just wasn't good enough and I realised the importance of a lower f stop.... I'm looking for one which has at least some range e.g. 10-20mm
If you can put the camera on a table (using the lens you have and use the 2 second delay to lock up the mirror and turn of shake reduction), you should be able to eradicate camera shake which I am guessing is your issue. The K-r isn't that behind the K-5 when it come to low light photography so you should be able to boost the ISO enough so as to give an acceptable image even by hand holding it.....my 18mm at f3.5 just wasn't good enough and I realised the importance of a lower f stop.... I'm looking for one which has at least some range e.g. 10-20mm
The only lens I can think of that meets the f stop criteria is the 14mm f2.8 already suggested. However it only gives you less than a stop increase in speed (however the extra width it gives could be useful.)
For zooms, an alternative to the Sigma possibilities already suggested is the Pentax 12-24mm but that is f4 or the 10-17 Fish-eye which is f3.5 at the wide end but gives noticable distortion at 10mm (it's designed to!)
If the lighting is seriously poor and you cannot boost it with extra lighting or flash you may need to look at a much faster lens. The widest f1.4 I can think of is the Sigma 31mm or the Pentax 50mm f1.4's. You'd get photos with these certainly but you'd have to be more selective with what you take. I don't think what you really would like exists in Pentax mount. The nearest might be the Tokina AF 11-16mm f2.8 but alas, not in PK. But in reality it offers little more than the Pentax DA 14mm f2.8. Users of the Tokina apparently reckon it almost feels like a fixed lens!
John
Posted 09/04/2012 - 21:58
Push the ISO higher Otherwise you are looking for a very expensive solution into a very rare problem
Posted 09/04/2012 - 22:44
Yes, that just about sums it up in a single sentence! Push the ISO higher Otherwise you are looking for a very expensive solution into a very rare problem
But if it's a shot that will stand a longer exposure (an empty restaurant!) then just make sure the camera is steady, set the camera to Av, drive mode to 2sec delay, stop down to about f8 and let the camera sort out the shutter speed for you.
John
Posted 12/04/2012 - 01:34
I think I may have found a solution which is to get either the Tamron SP 10-24mm f3.5-4.5 Di II or something similar and also a flash. That would solve the lighting issue and also allow me to have a wide angle lens at a higher f stop to get as much focus possible in the shot.
_________________________
Pentax K3
Vivitar 28-200mm f3.5-5.3 A Macro
Tamron 90mm f2.8 SP DI Macro 1:1
Pentax smc DA 55-300mm f4.0-5.8 ED
Sigma 30mm f/1.4 EX DC
Pentax 18-135mm WR
Pentax K3
Pentax 18-135mm WR
Posted 12/04/2012 - 05:56
If you are going to do that then any of the UWA will serve the purpose. Check your budget and what is out there, almost all have good reputations and plenty of supporters (Pentax 12-24, Sigma 10-20 (there are two current versions) or the Tamron 10-24).
Posted 12/04/2012 - 07:19
I can highly recommend the DA14 as well. Excellent lens.I have very good results with my Pentax DA 14. It does open to 2.8, but it is kind of bulky. If the bulkiness isn't a problem for you, then it should do the job for you.
You don't need 2.8 for low light these days because of good ISO performance. But many forget the shallower DOF available with wider lenses gives pics with depth
Posted 12/04/2012 - 17:09
Just a note that deep DOF (everything in focus) in a dark(ish) environment and (single) flash do not go well together. The problem is that a flash can only properly expose one subject at one distance; bouncing (if you have the option) makes the situation a bit better as it spreads the light a little more over a longer distance.
With AF540 (ISO200, f/6.7, 1/60s); notice that the end of the table is dark
Having a deep DOF will not help as there will be hardly any detail in the subjects further away, so why bother?
Without flash (ISO3200, f/6.7, 1/8s)
Also, pay attention when you buy a flash that you want to use with your UWA at 10mm as not every flash can cover that field of view.
Posted 12/04/2012 - 18:45
The natural light... looks more natural!! Surprise surprise!
Lighting a room like that with a single flash is nigh on impossible.
Using flash to evenly light a whole room would be like trying to light a TV production set. Tricky to say the least! It would need several flash guns set to fire as slaves - some to light the background, some to light the tables and each would need to be at the right distance/setting to avoid exposure mismatches. It would be a pretty complicated set up. It could be done with the restaurant owners permission for a formal shoot but not something you'd do casually and you'd have to swot up on flash photography techniques to get it right.
You say your 18mm at f3.5 didn't work. Rather than use flash, try again upping the ISO a bit more and shoot in RAW. I'm sure you'll boost the resulting image enough if need be afterwards. On a K-5 you really can take photos of black cats in coal cellars and the K-r isn't far behind.
Turn the lights down at home and have a practice.
John
John
Posted 13/04/2012 - 12:55
A standard flash will cover up to 18mm, possibly 16mm field of view. To get coveradge wider than that you will need to modify the light.
Flash: Metz 58, Metz 48
I'm looking for one which has at least some range e.g. 10-20mm or something similar. It needs to be at least f2.8 continuous, reason behind this is because I was in a restaurant with low light and my 18mm at f3.5 just wasn't good enough and I realised the importance of a lower f stop.
It must be AF as well, thanks in advance for any advice and help.
Pentax K3
Pentax 18-135mm WR
