wide angle lens advice required
Posted 30/04/2010 - 19:17
Wider than 18, non-fisheye, Pentax produced a 15mm 3.5 in the "K" and A series.
However these are rare beasts and you will have to pay more than a new DA15mm to own one ! Add to that the problem with flare you might encounter, I would suggest "old" is not better in this case.
You will do better to try and find a DA15mm or DA14mm. They will be better performers on a digital sensor.
Posted 30/04/2010 - 19:34
The full benefit of the K/A series 15mm is wasted on the cropped sensor, as is the 28mm Shift lens.
So probably better with a newer model lens.
Posted 30/04/2010 - 19:38
There was a K 17mm f4 fisheye too. Currently one is up for grabs on ebay, although it won't go cheap and has a reserve on it.
Posted 30/04/2010 - 19:46
Posted 30/04/2010 - 20:26
I'll shoot both, tomorrow on a K7 and post images. Same aperture and shutter speed. Haven't used the 15mm for some time.
Posted 01/05/2010 - 00:57
Posted 01/05/2010 - 11:44
I do not like fish eye. In my opinion nothing beats Sigma 10-20 for regular wide angle.
Posted 01/05/2010 - 12:34
OK, two quick shots. I'll shoot both, tomorrow on a K7 and post images. Same aperture and shutter speed. Haven't used the 15mm for some time.
K7 set at ISO 100 and 1/60th sec. Manual.
Both lenses were set at f/8. Central focus point used until beep heard. Shutter cable released. Only adjustments (levels-minor black adjustment and sharpened to 100% @ 0.3). No colour adjustments.
Posted 03/05/2010 - 01:02
The other point is that fisheyes designed for 35mm (ie all of them except the Pentax DA 10-17) will not give quite as dramatic a 'fisheye effect' since only the center, less distorted, part of the image circle is captured by APS-C DSLRs.
BRISTOL ENGLAND
All I seem to find on sale sites as wide angles are 28 mm which does not help i assume.
Is it worth spending money on a good quality [I hope]Raynox wide angle to increase the field of view? I don't want a fisheye as that effect is not what I want at all.
I am trying more to attempt more landscapes with a decent field of view with out resorting to a couple of images stitched together.
Alistair
