Wide angle
stigg
Posted 18/12/2012 - 23:47 Link
Thinking of a wide angle lens and am wondering what the general thoughts are on the sigma 10-20 or the 8-16?
All the best
Brian
And come him slow or come him fast it is but death who comes at last.
bychan
Posted 19/12/2012 - 00:45 Link
Brian
I have no experience of the Sigma 8-16, but do own the 10-20 (older model).
It's a great lens, as others on the forum will also testify.
However when you specify you're thinking of "a wide lens", what uses do you have in mind? There is a huge difference between say 18 and 10mm; for example I also own a Sigma 18-50 f2.8, and if I took a landscape image at 18mm, then the same at 10mm I would be looking through the viewfinder as if the foreground had moved back about 5 miles
It's difficult to explain the huge difference that 10mm offers, perhaps others can explain better than me.
To give a perspective of it's uses at 10mm, all of the following were taken with me standing literally next to the pier
link
If you do end up with a 10-20, I'm sure it won't disappoint and you'll have great fun using it.
Adrian
K5IIs, Sigma 10-20, Pentax DA 16-85, Pentax DA 55-300, Pentax 70 Ltd, Metz 44 AF-2.
Flickr: https://www.flickr.com/photos/ambott/
Smeggypants
Posted 19/12/2012 - 03:18 Link
I've seen great pictures taken on both the 10-20 and the 8-16. I wouldn't be disappointed to have either of them in my toolbox
The wide angles I do own are a Pentax 10-17mm and a Pentax DA-14mn/2.8. Both lenses exceed my technical satisfaction and as long as I press the shutter button at the right time, take cool pics
stigg
Posted 19/12/2012 - 07:20 Link
Thanks for the help, Ii have a 18-55 lens but would like something to fill the gap up to the 18mm for landscapes and general family pics and the 10-20 seems to fit the bill.
All the best
Brian
stub
Posted 19/12/2012 - 08:35 Link
Ive just recently made the step Of adding a Sigma 10-20 to my lenses. As I wanted something wider. Wow !!, what a lens. So sharp, and it opens up another world perspective wise. I would highly recommend one.
Stuart..
fritzthedog
Posted 19/12/2012 - 08:54 Link
Hi Brian
If what you are looking for is the ability to take very wide landscape shots - the Sigma 10-20 is outstanding and top of the list in terms of VFM.
IQ wise - I can see no difference between the older and newer version and personally would not pay a premium for HSM on a lens of this size - no benefit at all.
I bought mine 2 years ago and it is the only lens that I never leave at home. It probably accounts for 70% of al the images I take.
Some will undoubtedly say that the Pentax 12-24 is better but personally I can see no difference in image quality - they are both great lenses but the extra 2mm on the Sigma makes much more difference than you may think.
The 8-16 is also very capable and in terms of IQ - is up there with the 10-20. However - there is a massive downside with the 8-16 and that is you can not use standard filters on it.
If you are really wanting to get in to wide angle landscape - chances are that like most of us - at some point you will want to use ND grad filters.
For the 10-20 - any of the 100mm systems will work - Cokin Z- Hitech - Singh-Ray - Lee - Tiffen etc. At a push you can even get away with the smaller Cokin P system.
However - with the 8-16 - these can not be used due to the shape/size of the front element and view angle. Probably your only option would be the Cokin X-Pro 130mm x 170mm system and these are not easy to get hold of and very expensive. The basic kit including holder and a couple of filters will cost you more than the Sigma 10-20!!!!!!
My view - for what it's worth - buy the non HSM version of the 10-20 - find a good used example - and if you are one of the very few who finds they do not get on with it - re-sell without loss. Prices on these have not moved for some time.
Carl
Posted 19/12/2012 - 14:23 Link
Agree with all the thoughts above... don't have experience of the 8-16, but the 10-20 non hsm version is tremendous... take most of my shots with it... tend to use it as a 10mm prime... my copy sharpest f11-f14, though they do differ... and you can use the full range of nd/nd grad filters on it, so creatively the world's your oyster.... great vfm, and highly recommended...
Best
velimir
Posted 27/12/2012 - 16:45 Link
depends on the wishes and needs of the owner! I have long considered the "balance" between the Pentax and Sigma. The decision was Sigma 10-20/3, 5! Sometimes appears a little CA, but it's my fault (when manually continuation parameters). Last year I was the most wanted lens on their tour of Denmark! My photos "cliché" just missing that width?
greeting
Vrlimir
Magnum is law
AndrewA
Posted 30/12/2012 - 20:50 Link
Sigma 10-20 would get my vote. Not had mine long but have been very impressed so far.
PPG link
Flickr link
Conqueror
Posted 30/12/2012 - 21:00 Link
Have you considered the Samyang 14mm f2.8? (full frame and by what I've read so far very good VFM).
Samyang will also be releasing a 10mm at some point.
K-3ii
Jonathan-Mac
Posted 30/12/2012 - 22:42 Link
I believe the Samyang 10mm has been delayed until the end of next year.
I understand that the 8-16mm has high distortion until 12mm, apart from being big and not taking any kind of practical filter system.
