Which Macro ring flash
Posted 10/02/2008 - 13:16
Clarky,
A Montreal seller here uses this flash for his sales shots and I've always been astounded by the results.
The version that Henry's is selling certainly looks complete with the three adapter rings and all.
I have dealt with this seller often and find them to be extremely professional with fast communication etc. Write them about the K10 question.
Best of luck with this and I really look forward to your shots - as does every bug in your vicinity! You make them look so good!
Mac from Montreal
Posted 10/02/2008 - 18:34
The Pentax AF140C flash works well with all of the Pentax DSLR's as long as you are aware of the restrictions of this, and other TTL/manual flashes.
The K10D and other Pentax DSLR's cannot control the output of a TTL flash (the *istD can) so in manual mode, the flash will discharge 100%. You'll need to use a flash meter or experimentation to set exposure correctly. Experimentation only usually takes a few shots, just check your histogram on camera.
If you use the two TTL settings the flash still discharges 100% but the aperture will be fixed. Using my 100mm Macro lens and shutter priority (Tv) mode on the camera, the f5.6 setting on the flash results in a setting of f13 on the K10D, and the f22 setting on the flash results in a setting of f32 on the K10D.
Posted 10/02/2008 - 20:39
Peter,
f22 or f32 would be ideal for most macro shots where DOF is at a premium, no?
Maybe that's why macro shots with a ring flash are so sharp.
I've got to try my normal AF280T at full output with my lens stopped way down.
Whee, more stuff to try!
Mac from Montreal
Posted 10/02/2008 - 21:30
Ideal for maximum DOF? Yes. Ideal for best sharpness? No. f22 or f32 would be ideal for most macro shots where DOF is at a premium, no?
Most lenses produce their best sharpness at somewhere within a mid-range f-stop, not at their extremes. My SMC Pentax 100mm 1:2.8 Macro lens is best for sharpness at anywhere between f8 and f16. Some DOF is inevitably sacrificed to achieve optimum sharpness.
Posted 10/02/2008 - 21:34
There's just no free lunch, eh?
Mac from Montreal
Posted 13/02/2008 - 03:53
agreed with all points but when will PENTAX make a ring light which allows us to use their new toy PTTL which their other flashes have.
anyhow have a wonderful day everyone, and keep me posted about this.
Posted 13/02/2008 - 05:37
Pentax have always had a ring flash and I understood that a new version was in preparation. I think it's somewhat overdue...
Posted 13/02/2008 - 07:13
I have to agree. Pentax have always had a ring flash and I understood that a new version was in preparation. I think it's somewhat overdue...
Well the Pentax AF140C flash i was watching on Ebay went for US$380
So i need to find a good alternative, any recommendations John :
Camera:|K-7|
Posted 24/02/2008 - 00:41
I use the AF 140C for close-up dental work.
The latest KEH catalogue arrived recently and there were 3 AF 140C's for sale.
www.keh.com
www.keh.com
Posted 24/02/2008 - 01:25
What's wrong with your AF080C, Clarky?
Posted 24/02/2008 - 01:26
There really isn't much point in P-TTL for macro work. Much better to work manually.agreed with all points but when will PENTAX make a ring light which allows us to use their new toy PTTL which their other flashes have.
Posted 24/02/2008 - 02:21
This thread was posted before i found the AF080C, when i missed the AF 140C i went for the latter.
Camera:|K-7|
Posted 24/02/2008 - 03:23
With the results you get already I would have to really think about what gain I would get for the outlay on the new equipment. You're blowing us all away now with the fantastic quality of your macro shots, could you expect a significant improvement for the significant amount of money spent?
K100D Super, 18-55, 50-200, Sigma 10-20, Sigma 70mm macro and lots of old lenses
Sydney Australia
I am watching this one on E-bay
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=250213380735&ssPageName=STRK:MEWA:IT&ih=015
If anyone has used this flash i would like too know a bit more about it and if it will work ok with the K10
