Which lens and where?
Posted 28/03/2011 - 18:30 Link
Heres my issue. i have a pentax K10 D and have done for sometime and haven't purchased a new lens as couldn't afford it, however im going to work in south africa this summer on the national park and really am looking for a good lens with good distance. But if i'm honest i don't know which lens to get as there are so many and all this f2-3 or whatever i don't understand lol i know i probably should but i don't
Any ideas?
And also where could i purchase these lens you suggest, preferably any second hand places?
Cheers everyone who helps
Edited by the1theycallrichard: 28/03/2011 - 18:30
Pentaxophile
Posted 28/03/2011 - 18:37 Link
The smaller f numbers mean the lens will work better in low light or allow you to choose a faster shutter speed. The lower the f number, the more expensive and bigger the lens - at least with telephoto lenses.
If you are going to south africa, a telephoto zoom would be useful for wildlife, and the pentax 55-300 is a good but cheap option.
Dr. Mhuni
Posted 28/03/2011 - 18:42 Link
From the sound of it, you probably want a consumer telezoom. The Pentax DA55-300 seems to be pretty universally acknowledged as the best in its class in the Pentax fit. It comes in two forms one with a plastic mount - DA-L (which is cheaper and doesn't include a hood); and the other a metal mount - DA. They are optically identical though. If I was buying s/h I'd definitely go for the metal mount (for the hood & robustness). They come up fairly regularly in the classified adverts section in this forum for +/- £200.
If you're buying new - SRS the 'official shop partner' of this site (click on add to the right of this) are hard to beat for both service and price. They may even have a second hand one.
Edit: Pentaxophile got there first.
Mhuni
500px
Edited by Dr. Mhuni: 28/03/2011 - 18:43
thoughton
Posted 28/03/2011 - 18:43 Link
Are you planning on taking your existing lens as well as the new one? If so then Pentaxophile's suggestion is a good one.
If you want to keep it at a single lens the Pentax/Tamron 18-250mm lens is supposed to be unusually good for a lens with such a large range.
Tim
Posted 28/03/2011 - 18:58 Link
pentaxaphile thats was weird i was just looking at that lense when you said it I've had a look at it and it seems a good all round lense for the price as well, the only issue i've found with it is its slow focus but for the price i'm sure i could look past it.
Thoughton thats a point with the tamron i could leave my kit lense at home and just take the tamron. Does it fit a pentax? Any thoughts on which one is a better lense?
Thanks for your help guys
Dangermouse
Posted 28/03/2011 - 23:29 Link
You can buy the Tamron to fit many different cameras IIRC, just ask for a Pentax-fit one when you buy. The current Pentax mount is called the K mount and has been around since 1975, so anything made since then by Pentax will fit with some limitations on earlier lenses.
I would imagine the kit lens* is the better one. Generally megazooms are forced to have more compromises than a normal zoom, which reduce image quality. While the latest ones are more than adequate I'd still expect better performance from an 18-55mm than an 18-250mm.
*no "e", it's lens or lenses!
Edited by Dangermouse: 28/03/2011 - 23:31
greynolds999
Posted 29/03/2011 - 14:16 Link
If you can make the trip out to Beauly then Ffordes have a lot of second hand pentax. You could see how things look when they are on your camera and see if you're happy with them.
www.ffordes.com
MrCynical
Posted 29/03/2011 - 15:21 Link
The 'problem' with the Tamron/Pentax 18-250 (the 'Pentax' lens was a rebadged Tamron) is that it is : a) Discontinued and b) Popular. That means that there aren't actually all that many available second hand.
In terms of image quality, you would be better to buy the 55-300 others have mentioned (and take your 18-55mm kit lens too, for wider shots) - this will also be substantially cheaper than the 18-250 (which was £400-odd new IIRC). However the 18-250 is widely regarded as the best of the various 'superzoom' lenses (ie those which go from 18mm to 200 or 250mm).
Gwyn
Posted 29/03/2011 - 16:08 Link
Don't forget Sigma still make an 18-250. And of course the Bigma .
Dangermouse
Posted 29/03/2011 - 23:13 Link
Sigma make something that doesn't end in "-500mm"? What on earth for?
Eastridge
Posted 30/03/2011 - 09:57 Link
As someone who has both the 18-250 and the 55-300 I have to say on your trip I would take the kit lens + 55-300 if I could find the room.
Whilst the 18-250 is remarkable quality for the range it gives , I think that -
- the extra 50mm - between 250 and 300 will be important in getting decent shots of wildlife at a distance
- the quality at this 'long end' of the 55-300 is better.
I suspect that those who can afford it (not me!) would take a Sigma something to 500 on such a trip so the longer you can get the better.
Sharon's: K-x, FA35/2, DA 18-250.Glen's: K10D, DA100 Macro, 55-300, Paragon 500, Silk Pro700 Tripod
wuttwutt
Posted 30/03/2011 - 10:46 Link
I just got the K-r kit (18-55 and 55-300). While I love the extension of the 300, it still doesn't allow me to get as close as I would like. I'm going to be looking for a larger lens as soon as I can save the money.
Dangermouse
Posted 30/03/2011 - 11:18 Link
If you're going to be working then I don't see the Bigma as a solution. It's just too, well, big!
I guess it depends on what you're doing, but from personal experience if I was going to be a guide/driver on a safari I'd want a relatively compact lens. Wildlife will often come very close to vehicles from what I hear, so you don't necessarily need anything long. Also worth bearing in mind that with lions wandering around you really won't want to open the window wide enough to stick a lens out!
From experience of leading 4x4 groups here I find either my 35mm prime or 18-55mm zoom do the job. I wouldn't mind something like the 16-45mm f4, but last time I didn't find I missed much with the 35mm. It also makes the camera small enough to perch on the centre console behind the gearstick, where it's easily to hand.
Gwyn
Posted 30/03/2011 - 11:24 Link
South African safari vehicles tend to be open - no windows at all.
East African safari vehicle have a pop roof so you stand up and take photos through the roof, or through the wide open windows. Lions are so used to vehicles you are in little danger, unless you get out when you are recognised as prey.
A driver guide doesn't not take photos - he looks for wildlife and leaves it to the guests to get their shots. If he is taking photos too he can't be watching out for potential danger or other wildlife.
It takes a lot of training to be a driver guide.
Yes the wildlife can be close to the vehicle but it can also be a long way away, in which case 300mm is not enough, especially for birds and shyer animals.
I don't find the Bigma too big, and would rather have that than have to keep changing lenses.
Pentaxophile
Posted 30/03/2011 - 13:51 Link
I see someone's offering a Tamron 70-300mm for a good price in the classifieds Richard. It has worse 'purple fringing' but is a lot cheaper than the Pentax, and is otherwise said to be on a par IQ wise, so probably worth a punt.
