which battery
Posted 17/10/2008 - 17:20
Rechargeables are ok before Ni-MH I used Ni-Cads in all my winders in my film days. Both types are 1.2 volts which is lower than alkalines which are 1.5 volts..
Tel,
I can't imagine that the performance of the Winder ME II will be affected very much by using NiMh batteries.
If you don't use it often, I'd suggest using Sanyo's Eneloop batteries as they have a very low self discharge rate and are said to maintain up to 80% capacity even when not used for a year. The same cannot be said for most NiMh batteries.
I find that after only a few weeks, Uniross batteries can lose their charge.
Posted 19/10/2008 - 16:39
Thanks for you`re help.
I was just concerned about damaging the winder as it was not designed for rechargeable batteries.
Rick
Rick
Posted 19/10/2008 - 17:51
Don't worry, you won't damage it. Not electrically anyway. Rechargeable batteries have a lower operating voltage (1.2'ish) than alkaline or lead acid batteries (1.5v).
I prefer Eneloop batteries for their charge life, and physical size. They are closer to the size of alkalines whereas I find other rechargeables to be very slightly longer. This will not affect you, but it can reduce the life of some flash gun battery door catches.
Posted 19/10/2008 - 18:02
Thats an interesting point about the size of rechargeables.
I have used uniross batteries in a Metz flashgun, and the battery door is a bit akward to close, did`nt realise there is a physical size difference.
Rick
Rick
Posted 19/10/2008 - 20:23
Actually, the MEII winder catch is notoriously weak and can break easily (I was like a pig in smelly stuff when I managed to buy a brand new replacement catch on ebay!) so using the Eneloops might be a good choice for winders as well as flashes.
Cheers, Kris.
Cheers, Kris.
Posted 02/04/2011 - 04:01
I found rechargeable (NiMH 1.2V) batteries simply - most likely due to the voltage difference - would not operate the winder motor strongly enough to advance it at all, and were quite useless. I popped in nearly-new alkaline 1.5V cells, and it worked perfectly (and is still doing so, on the same batteries).
Now, maybe my winder needs a service, and a good old lubricate; but that was my experience. Bit of a 8ugger, as I've LOADS of reachargable AA batteries from my learning days with a (still lovely - esp for IR shots - you can SEE the image on the screen, as there must be almost no IR filter over the sensor) Fujifilm S7000 hybrid
If I sound condescending, it's just my style Much more equipment than know-how, so seeking to catch-up.
[K10, ME-super, lenses, flashes old and new (old - Pentax AF160 AF400FTZ; new Metz 58 AF-1, 48 AF-1, 15 AF ring), tripods, filters, connectors, converters, eye-pieces, rings, SPLENDID old Sekonic meter, bellows, 2-way rack, slide copier and lots of bits and bobs for mysterious things I don't have a clue about ...
20 years
hampshire
Will these cause a problem with the winder or should I stick with alkalines?
Rick
