Which 80-200 zoom to keep?
Posted 16/05/2009 - 22:15
The M version is likely to be the better lens because it will benefit from SMC coating. Weigh it. If it weighs around 615 grammes its the version 2 lens (12 elements in 9 groups, same as the Takumar lens), if around 555 grammes it's a version 1 (15 elements in 12 groups.
The Takumar lens, despite the kudos associated with the name, is a budget, non-SMC lens.
Edit: I got the version number info transposed.
Posted 17/05/2009 - 00:23
Mannesty wrote:
The M version is likely to be the better lens because it will benefit from SMC coating. Weigh it. If it weighs around 615 grammes its the version 2 lens (15 elements in 12 g roups), if around 555 grammes it's a version 1 (12 elements in 9 groups (same as the Takumar lens).
Thanks for that, most informative. What's the significance of the version number? Is one better than the other? I think it's a pretty early lens, probably from around 1980.
Posted 17/05/2009 - 00:25
I would get rid of both and replace with an SMC Pentax-A 70-210mm f4.
~Pete
Posted 17/05/2009 - 11:44
Don't sell the 'SMC Pentax-M 80mm-200mm 1:4.5' very sharp lens especially at 200mm and objects beyond 30m away. Beautifully made as well which can't be said about current stuff. Mine was better than the M 200mm f/4 prime so I sold that. Fabulous colours on Digital and purple fringing isn't much of a problem with this lens.
Mine weighs 570 grams without the caps.
Sell the Takumar.
shim
Sell the Takumar.
shim
Posted 17/05/2009 - 19:26
OK, thanks for the feedback. I suspect if I sold the two I wouldn't get enough to buy an SMC Pentax-A 70-210mm f4, as my Pentax SMC has a minor 'dink' on the barrel which doesn't affect it optically but would certainly reduce the selling price. I'll keep that one and sell the Takumar, and keep my eyes open for a 70-210mm on the cheap.
