Where can I get my camera repaired
Posted 20/02/2011 - 12:29
Before sending it in for repair, is it set on AF-S or AF-C? If it is on AF-S, it shouldn't release if the focus isn't done.
Posted 20/02/2011 - 15:24
Or, is the autofocus switched off? Do you hear the motor whirring when the button is pressed as well?
Might be worth taking off the lens, and re-seating it - in case somethings jammed.
k5, 50mm FA, 18-55mm Kit, 50-200mm DA, 15mm Fisheye Sigma, 10-17mm DA Fisheye, 18-55mm DA WR, DA* 60-250, DA* 16-50
Posted 20/02/2011 - 15:45
Maybe worth trying resetting the Custom Function menu to the defaults (page 180 of the camera manual.) One of the settings turns off automatic focussing during a shutter press.
John
John
Posted 04/03/2011 - 07:44
I've tried the above and it is definitely a mechanical problem with the button. It feels like there is no resistance when you press so the button can not be held at the halfway position - it just goes all the way down.
So. I think it needs a new shutter release button but I don't want to pay much as there is not a lot of value in the K100D these days. Any ideas?
https://pentaxphotogallery.com" target="_blank">
https://pentaxphotogallery.com/images/black_link_small.jpg" alt="See my photos featured in the PENTAX Photogallery" />
Posted 04/03/2011 - 07:54
JP Service Solutions is the official repair facility in the UK. They are not overly expensive, but can be quite slow.
Posted 04/03/2011 - 08:15
I have used JP a lot. I have found them to be very helpful and efficient. The speed is due to where your repair fits in to the queue, as prority is naturally given to warranty repairs.
Leeds,
The North
Any recommendations of camera repair shops for the Leeds/Bradford/Harrogate area?
