What Tripod plate do you use?
Posted 12/02/2014 - 14:54
Arca Swiss. I've a ridiculously unbalanced long lens to mount up on a gimball so having extra long plates is a huge advantage for me.
Posted 12/02/2014 - 20:16
Never heard of an Arca Swiss. I use manfrotto QR plates
[Nerd Voice]
The Manfrotto MN-200PL-14 Quick Release to be specific
[/Nerd Voice]
I have them permanently fixed to the baser of my cams. they also act to protect the base when resting the cam on walls, etc
[Nerd Voice]
[/Nerd Voice]
Posted 12/02/2014 - 20:21
I use Arca Swiss type QR plates too, since that is what my Markins head uses. I too have a couple of long plates for long lenses.
It all depends on what head you have on your tripod which QR plates you use.
Posted 12/02/2014 - 23:21
I use a Kood ball head with QR plate. AFAIK, it is not compatible with Arca Swiss stuff.
Posted 12/02/2014 - 23:34
Posted 13/02/2014 - 06:41
Same here, I use the screw up type clamp, not keen on the lever version
Posted 13/02/2014 - 09:16
leytono wrote:
Same here .
Same here, I use the screw up type clamp, not keen on the lever versionI use Arca Swiss type QR plates too, since that is what my Markins head uses
Posted 13/02/2014 - 09:50
This is why I'm thinking about the Arca type. Not that keen on the lever with my current QR and the Arca type has a screw.Same here, I use the screw up type clamp, not keen on the lever version
This is what I have in mind, I already have the head.
[IMG]http://www.borge.com.au/images/giottos_mh1300-657.jpg[/IMG]
K5, LightRoom 5
Posted 13/02/2014 - 10:13
Well one of the good things about Arca plates is that it's a widely used design so you can get a really cheap one from China to see if you like the design
FWIW I've been using some 'Rainbow' branded long and stupidly long plates (available on Amazon) which are nicely made and not expensive.
Posted 13/02/2014 - 10:28
There's nothing QUICK about the Arca plates. You have to slowly unscrew the release and they (and the camera) slip off very easily unless you put grubs screws in as stops. This further slows down removal. Your also stuck with a big plate underneath the camera.
I've got about 5 Novoflex MiniConnects which for safety require two levers to be pressed before release. Putting on is a doodle they just click in place. You can also QR a camera strap.
http://www.novoflex.com/en/products/camera-support-systems/quick-release-systems...
If I need to use a Plate or the L-Bracket I have a Panorama-Q Head with a QuickConnect Coupling piece on the bottom. Takes seconds to change over.
http://www.novoflex.com/en/products/panorama-photography/panorama-plates/
Novoflex and Arca plates are almost the same and usually interchangeable.
There's also a Quick head for the plates with a safety pin ....
Posted 13/02/2014 - 11:35
The Giottos plates come in lots of sizes so size need not be an issue. They also have an auto lock pin as well. Only trouble is I can't find a MH657 in stock anywhere.
http://www.giottosusa.com/quick-releases.shtml
K5, LightRoom 5
Posted 13/02/2014 - 12:37
The Giottos ones seem to all hide the spirit level when in use.
For use with an L-Plate on a small tripod I bought a Sunwayfoto one.
They are quite well made and take any plate.
Similar_on_Ebay
Similar_on_Ebay
Posted 13/02/2014 - 13:30
So does the Novoflex, buts it's no big deal, just slide the camera forward if you want to view the bubble.The Giottos ones seem to all hide the spirit level when in use.
I quite like the look of the Novoflex one, it's on my list.
K5, LightRoom 5
Posted 13/02/2014 - 13:42
Looks very nice in fact.
http://youtu.be/0mtCUgmdGhg
Only problem is no safety pin?
Edit. It says it has a pin on the site but I can't see how it works?!
K5, LightRoom 5
Surrey
