What lens you using for astro?
Conqueror
Posted 11/10/2013 - 23:18 Link
K-3ii
PaulEvans
Posted 12/10/2013 - 09:08 Link
For aurora and milky way (i.e. wide field night sky shots), I use a Sigma 15mm f2.8.
Not tried any digital astrophotography of any smaller objects, but for the moon something north of 500mm would be useful, and for any smaller / fainter objects than that you're talking telescopes and guiding.
Paul
K3ii, DA16-85, DA35mm Limited, FA77mm Limited, 55mm f1.8 K, 135mm f3.5 M, DA300, DA 1.4 HD TC,
DA16-45, Sigma 15mm f2.8. Cosina 100mm f3.5 macro
DrOrloff
Posted 12/10/2013 - 09:12 Link
Or for deep sky objects a long lens the O-GPS1 and some stacking should give some nice results.
Conqueror
Posted 12/10/2013 - 12:40 Link
Yes I'm hoping to get an O-GPS1 at some point and compatable camera body... currently got K-7
I thought I'd give the DA 15mm f4 prime a spin with it (which I alread have)...
Though I'm also wondering about picknig up a wider fisheye if I can afford, the Samyang 8mm or Pentax 10-17mm perhaps
K-3ii
Mongoose
Posted 14/10/2013 - 13:16 Link
The best I've ever managed was this:
[IMG]http://img.photobucket.com/albums/v68/thatguypinchedmyname/andromeda-s.jpg[/IMG]
Tamron 300mm f/2.8 SP lens on a K10D, several stacked 3 minute exposures mounted on a Celestron CG-5 equitorial telescope mount.
but it does help
Posted 14/10/2013 - 19:06 Link
Very good result there Mongoose, I'd like to have done as well.
Smeggypants
Posted 15/10/2013 - 03:47 Link
Trivia: The effective focal length of the Hubble telescope is ...
57600mm and is f/24.0
http://space.jpl.nasa.gov/msl/QuickLooks/hstQL.html
However it's not a Pentax Model or available in K mount so better not say any more!
Mongoose
Posted 15/10/2013 - 12:09 Link
when I lived in Cambridge I had access to the telescopes on the "hill" at the University astronomy department. The larger of the two was roughly a 5000mm f/16.
Alas I never managed to get my K10D mounted on it, it was amazing to look through though, particularly good for planetary astronomy.
There's something about ~10 tonnes of victorian ironwork which is so finely ballanced that you can move it with one hand.
but it does help
Edited by Mongoose: 15/10/2013 - 12:11
Posted 15/10/2013 - 13:23 Link
I suspect you could fit a K mount camera to the Mount Palomar telescope, perhaps that would be long enough for most purposes?
Mongoose
Posted 15/10/2013 - 13:34 Link
you'd need a substantial bag to carry it around in though John
but it does help
Posted 15/10/2013 - 14:05 Link
Billingham will be my friend....
G1DRP
Posted 17/10/2013 - 13:09 Link
I've thought about trying my Tair 300mm f4.5.
I also have a 50mm f1.4M series lens which I bought on the cheap as it had some fungus on the internal surfaces of most of the elements. I cleaned it out and it's clearer than my "mint" example now.
The last time I had a go was in 1997 and I used a 50mm f1.7 on an ME Super with good results. I used Fuji 400 ASA slide film and pushed it to 1600.
Cheers,
Ian
petrochemist
Posted 18/10/2013 - 17:08 Link
If I could afford the delivery charges I'm sure convertion would be a minor issue There's likely to be plenty of room for an adapter if you want anything closer than infinity - just think how much extension you'd need to focus down to mere 200m.
Father Ted
Posted 20/10/2013 - 20:08 Link
Cracking shot!! (I've never managed to find Andromeda, but not for lack of trying!)Is that cropped?
I'll have to give the Orion nebula another go this winter. I hadn't thought of using my 300mm, I tend to think of mounting to my scope all the time.
What stacking software did you use? I have a free version of Registax somewhere, but never got round to installing it.
