what is your tip when using manual focus under f2.0?
When manually focusing I don't use the focusing aids at all, never did, and just visually focus using the ground glass field.
Some do find this difficult and then focusing aids come into their own. When AF becamke available though these were dropped because they can interfere with AF systems.
Split screen focussing screen - usually, but not always, perfect focus, but convenient to use. A bit scary to install the first time you do it, a doddle after that.
There are also people grinding down Canon EE-S focus screens to size to use in Pentax cameras. Even higher scary factor
Doesn't a split screen affect the metering?
When manually focusing you need to be aware that there is a 'zone' of 'in-focus' when the green hexagon lights up. I've found by habit I usually focus from near to infinity and the green hexagon will come on when I enter the 'zone' - however in actuality as I enter the 'zone' the shot isn't in focus. Therefore I've now trained myself to start focussing from infinity to near and then when the green hexagon comes on it IS in focus. Obviously this matters much more with low DoF shots.
N.B. Every lens is different. The infinity to near works accurately on 90% of my lenses but with a few of them it's vice versa and actual focus is reached when entering the 'zone' from near to infinity.
I've got a Cosina f1.2 in the post so we'll see if it works at that DoF !
I experimented with a split image screen, not so good with slower lenses and a bit of a nusiance for macro work, but otherwise good.
I'm now back to the standard screen where I use the green hexagon in-focus indicator and find it very good.
After a recent thread on here I've been experimenting with catch in focus and finding is very useful in most situations - its a bit like an autofocus lens with your hand on the the focus ring as the motor.
Another useful bit of advice is to make sure you eye is right up to the finder (and of course the dioptre adjustment is right for you).
The "red focus light" does not indicate you are in focus
Hi.
I have pentax a 50mm 1.4 lens and am experiencing difficulties in using manual focus.
Especially, under aperture 2.0 how do you use manual focus? any special tips?
If the red focus light and the beeping sound is not working accurately, is there any function to turn it off?
I am always amazed to see how others photos are well-focused and captured and I would like to learn from you.
Thanks.
You can calibrate the AF for manual lenses ( for those cameras with AF calibration parameters ), but you'll have to dial it in manually for each lens.
It does flash when the camera thinks focus has been achieved though
I don't think there are any tips, just practise until you get it right. On the old VN plate cameras I was trained on as a young a press photographer, we had a 135mm standard lens on a 9x12 plate. For a '2 yarder' as we called it,
usually a portrait, you had hardly any depth of field. But, given that these cameras had no rangefinder, you had to learn to judge it.
Getting a 'fuzzy' was beyond the pale and the senior guys would spare you no humiliation (and sharp digs in the ribs) if you got it wrong. It's surprising, even given such encouragement(!), how accurately you can judge distances to within an inch at 6 feet. But, a skill largely lost now.
United Kingdom
Thanks.
