What have I done?
Posted 16/01/2012 - 13:30
Take the battery out and insert again? Remove SD card?
Hi. My name is Joel and I'm a travelholic.
Stolen kit: Pentax K7 #3428965 and Pentax FA 43mm #0028350
Posted 16/01/2012 - 13:35
I don't normally have the instant review on, but I just tried it for you. I get the hourglass too. I am shooting RAW, and it takes a while for the photo to write to the card - which is why you get the hourglass.
It is perfectly normal. I suspect you have just not noticed it before.
Posted 16/01/2012 - 13:36
Tried both of them and that didn't work. Thanks for trying.
Pentax K1-ii and MZ6
ONE UNITED Member
ONE UNITED Member
Posted 16/01/2012 - 13:37
I don't think this is normal but I could be wrong.
ONE UNITED Member
ONE UNITED Member
Posted 16/01/2012 - 13:58
Have you got "lens correction " turned on (screen 1 of the record menu)? I found that this slows mine down considerably. It is not obvious if this is turned on in the menu. You have to go into "Lens correction" to see what state it is in.
If all else fails, and assuming that is not how you put the settings back, then the "Reset" function in screen 3 of the settings menu will put all the general settings back to default (but not anything changed in the customisation menus). This could be a pain if, like me, you like to have it setup with non-default settings so might be worth making a quick record of the existing settings first.
Glyn
Glyn
Posted 16/01/2012 - 16:17
Glyn is absolutely right ... if you have Lens Correction (menu : Camera - page 1 - Lens Distortion) turned on (either Distortion or CA or both) then it will slow down the processing immensely. Switch it off and do it in PP if absolutely necessary !
Posted 16/01/2012 - 16:54
Its certainly not normal, mine isn't showing a timer before it displays a picture. I'm not brave enough to repeat what you did though. What version of the software have you got?
K5 + 18-135mm kit lens
Posted 16/01/2012 - 19:03
It was turned on, don't remember doing that, not unusual for me at my age, but I will have to wait until tomorrow to try it as it is dark now. Thanks very much.
ONE UNITED Member
ONE UNITED Member
Posted 16/01/2012 - 19:19
Just to add to it...exactly same happened to me and turned out to be lens correction turned on for distortion and CA. As soon as i switched off it went back to normal.
Posted 17/01/2012 - 11:01
Problem solved, it was the lens correction. Thanks everyone.
ONE UNITED Member
ONE UNITED Member
22 years
Handsacre
The other day I set the camera, a K5, to shoot with bracketing the shot.
Ever since then back on single shot, the camera takes its time to reproduce the image on the LCD, it shows an hourglass. It never did this before. I have reset evrything back to the original setup and it still does it. How can I stop it? Many thanks.
ONE UNITED Member
