What a differance help makes
Dordrecht,
the Netherlands
USM - link
High-pass - link
Which one is the best depends one your photo, sometimes USM works better and other times high-pass so I suggest learning them both, you can even combine the two.
ps. in the tutorial he talks about how you can't use layer to control USM but you can.
Put the blending mode on Luminosity and with the opacity slider you can let the original photo come through more so effectively lowering the effect of the USM, it's not perfect though.
K10D, K5
AF-540FGZ
