What 'could be' a Pentax lens
whelmed
Posted 08/04/2010 - 18:56 Link
I'm not going to link all the lenses I'm shopping for, because at least one of them has a typo in their title on Ebay, and just don't want more competition that I'll already have ... however, this one I don't think anyone else here is mad enough to try to snipe from me.
So it seems that part of my job is already done for me. I've got friends coming over from 'merica so I can ship it to them to avoid the P&P charges. I will, of course, tell them to declare it for me at the boarder though. At any rate, am I *mad for looking at this? The glass looks spot on. I doubt that even if I wired up the HSM to a pentax mount which had HSM on it that it would work (Sigma would probably have to flash it), so I would be doing this as a fully *MANUAL 300mm f2.8.
The register is larger than Pentax so that makes things a lot easier as well (no shaving / milling required)
Thoughts? What would you pay for a 300mm f2.8 manual lens of reasonable quality?
Edits: Man, me is smrt today with the tyopng
K-5; Siggy 10-20 f4, 30mm f1.4, 18-50mm f2.8, 70-200mm f2.8; Tammy 400mm f4, 500mm f8
Edited by whelmed: 08/04/2010 - 19:06
whelmed
Posted 08/04/2010 - 21:11 Link
Really, 52 views and not a single thought as to what this should be worth? Lets assume that the conversion will work flawlessly - do you think it would be worth 80GBP to have a 300mm f2.8? Hell, other than the tammy that would be the fastest 300mm on a Pentax
womble
Posted 08/04/2010 - 21:16 Link
I wouldn't know where to start with repairing/converting it but if you think you can sort it, then it is worth a punt.
Cheers, Kris
Anvh
Posted 08/04/2010 - 21:20 Link
The biggest problem is the aperture, you will only be able to shoot wide open with this lens and without the ability of stop-down metering.
As for the adapter, get a very cheap Pentax lens just for the K-mount and screw that on the lens.
Stefan
K10D, K5
AF-540FGZ
Edited by Anvh: 08/04/2010 - 21:21
whelmed
Posted 08/04/2010 - 21:26 Link
Wouldn't this lens function as a like any other SMC-M lens? I'd just have to repair the aperture control and I can set it manually on the lens.
Anvh
Posted 08/04/2010 - 21:49 Link
Oh wait the aperture ring is the part that was broken off
Yes if you can fix that it would work like a M lens.
Let him confirm however that the aperture blades still moves freely, if not you might end up rebuilding almost the whole lens completely
Stefan
K10D, K5
AF-540FGZ
whelmed
Posted 08/04/2010 - 21:58 Link
Yeah, I messaged him about that, waiting to hear back from him. They have no idea bout cameras so it's tough to get them to do what I want them to do.
Malo1961
Posted 08/04/2010 - 22:01 Link
I would advice against it. The way it was broken suggests a real hard bump/fall at a angle which caused this fracture. Also the rear focus element seems to have a large dent and isn't looking to round any more.
So the internal focussing construction is likely damaged.
Which.....degrades this lens to nothing more as a very expensive doorstop.
What ever money you pay for it. Walk away from it.
Best regards,
Martin.
hefty1
Posted 08/04/2010 - 22:12 Link
To be honest that lens looks like it's had a very hard life - I wouldn't give it house space if I was paid to, far less pay good money for it.
As Martin points out it's likely to have had a collision at some point and if the elements are knocked out of alignment then it's no longer fit for purpose. The only person who could use such a lens would be someone looking for spares for an identical model.
But it's your money...
Joining the Q
whelmed
Posted 08/04/2010 - 22:17 Link
I hadn't notice the ding on the inner ring till you mentioned it - however, isn't the focusing ring in the middle of this lens where the rubber is? I'd be surprised if the focus mechanism actually moved the lens and wasn't entirely internal.
The seller got back to me and said "Blades are there and aperture is at minimum, after the aperture is opened up by moving the lever, the aperture is stuck at wide-open." So, to me that would imply damaged blades. Now that is a bit of a downer.
Edit: New message from seller: "Aperture is stuck at wide-open and will not goes down again."
Edited by whelmed: 08/04/2010 - 22:20
hefty1
Posted 08/04/2010 - 22:22 Link
The elements in any lens are held together in a strictly regimented fashion and deviations of even a fraction of a millimetre can ruin performance. When you see a dent like that there's always a fair chance of internal damage that transforms it into a glass and metal door stop.
There's a good reason why it's looking so cheap...
Joining the Q
Anvh
Posted 08/04/2010 - 22:26 Link
Doesn't have to be if they move freely, it's a simply spring that retracts the blades to their resting position.
Stefan
K10D, K5
AF-540FGZ
whelmed
Posted 08/04/2010 - 23:32 Link
I read that as it's stuck, so I think I'm going to pass on this one. Shame, I'd really like a 300mm f2.8
whelmed
Posted 10/04/2010 - 11:31 Link
WTH - £200.27 was the closing price (before shipping) Wow, someone really wanted that lens!
Posted 10/04/2010 - 11:35 Link
Perhaps somebody already had all the parts to repair it.
