Whale and Dolphin Watching
rscoote
Posted 30/01/2012 - 13:25 Link
I have a trip planned to the South-West of Ireland in early August and have booked a trip on a small boat, 12 passengers, with a marine biologist captain. The intention is to see dolphin, porpoise, fin whales and minke whales if we're lucky. Also chance to see Atlantic seals on rocks by the water's edge.
My first question is for advice on technique and resources. Is there a good book, internet site or advice from the learned members here that could help me increase my chances of getting some good shots?
Secondly, what about equipment? Probably the best images would be dolphins leaping from the water and I understand that if you're fortunate they can actually come quite close. I have a K20D, 100mm Macro f2.8 WR and DA 55-300mm but there are faster zooms (Pentax and Sigma) and I assume WR would be a good idea. Where, if anywhere, should I look to upgrade?
Any experienced marine wildlife Pentaxians than can help me?
My PPG link
K-3, K-5 + D-BG4 Grip, Pentax: FA 50 1.4, DA* 300, Sigma 70-200 2.8 Macro HSM II, Sigma 18-50 2.8 EX DC, Metz 58 AF-1
Edited by rscoote: 30/01/2012 - 13:26
Posted 30/01/2012 - 13:41 Link
For what you describe I would be looking at taking the 55-300mm and a wider zoom. The 100mm macro won't really help at sea.
So, what lens? The candidates are probably 18-55mm WR and 18-135mm WR and any of the other wide to medium telephoto zooms. At sea I would probably use a UV or Skylight filter, just to protect the front element from salt water spray.
rscoote
Posted 30/01/2012 - 14:07 Link
Thanks John. I have a Sigma 18-50mm f2.8 EX DC. Good IQ but not it's not WR. I wondered if a Sigma 70-200mm f2.8 (enabling faster shutter speeds to stop movement on the dolphins and the motion of the boat) or a Pentax 60-250mm f/4 (slower but weather sealed)would be recommended?
My PPG link
Posted 30/01/2012 - 14:15 Link
I don't think you then need another lens. It is possible to tape a platic bag around a non-WR lens and keep water spray largely at bay.
Personally, the 18-135mm could be ideal, if I were making the trip you are making that would be my lens of choice, plus the 55-300mm protected as best I could.
F2.8 lenses are not essential as increasing ISO can be quite sufficient. The K20D probably should be kept to ISO 400 or lower if at all possible though.
Gwyn
Posted 30/01/2012 - 14:17 Link
Take the 55-300, a skylight filter and a plastic bag with a couple of elastic bands (or if you are feeling flush the OpTech rainsleeve. Put the bag over the lens and camera, cut a hole in it for the lens to poke through and hold in place with an elastic band. Allow for the zoom action and put another band around the bag near the body. Cover the body with it too, to protect the whole kit. The rainsleeve looks better but the bag will do the job.
The zoom will be perfect as you may find the animals coming surprisingly close to the boat.
Be prepared for lots of photos of sea or odd bits of dolphin/whale but you will get some keepers too.
We've been lucky enough to go whale watching off Boston, La Palma and Seattle and I took the Bigma with me, but many of the shots were at the 70 to 250 range.
Frogherder
Posted 30/01/2012 - 16:33 Link
A length of nylon cord and a plastic float might just come in handy should the worse happen.
Sure the camera will get wet but it shouldn't finish up on the bottom of the Atlantic
Bernard
rscoote
Posted 30/01/2012 - 19:22 Link
Thanks for the suggestions so far. I feel more comfortable that the 55-300mm range will cover most eventualities and I might change to the wider zoom if I'm feeling brave and/or in calmer waters. I'll definitely consider a rainsleeve / rain protector (they seem quite cheap on Amazon so I'll consider stretching my finances, Gwyn) and a UV filter for spray protection.
Bernard - I'll attach my camera to my wife with a length of nylon cord; she looks quite buoyant and it will save me from temptation if she starts complaining about the trip. I wouldn't want to lose a perfectly good camera.
Roy
My PPG link
Don
Posted 30/01/2012 - 19:40 Link
remember the composition.... we did some whale watching with our boy here is what I found:
telephoto shots of the whales and dolphins in the water from a distance were pretty boring compared to the shots of the people and boats doing the watching....
anticipate where the action WILL be, you won't likely get much if you try to follow the action..
keep your video camera rolling the whole time...
so I had three cameras rollin.. one video cam, constantly rolling, one d-slr with telephoto lenses, and one d-slr with wide angle lens...
got my wife to use the video cam while I manned the d-slrs.. we got up high in the center of the boat and shot from there... so we could get the shots no matter where the whales and dolphins popped up.
have fun
Stuey
Posted 30/01/2012 - 20:41 Link
Hello
I was lucky enough to go out on a dolphin watching boat in New Quay, Wales. There were a few local uni scientists on board (it was outside term time) - sadly only a quick glimpse of a fin tip over 500 yards away though
However, I did learn that if I go again my K10 will be covered with a plastic bag as mentioned above, also when you get back from your trip don't wipe your uv filter as the salt in the water could scratch it - give it a good rinse instead initially - also it can be pretty rough at times and as such I would attach an additional wrisp strap - one that will not come off without a fight as dropping your camera is a real possibility as people around you can tend to fall about a it depending how crowded the boat is plus the scramble to point the lenses can be a bit of a struggle
Last point from me is that even in summer it can be a bit chilly - my choice was a pair of walking trouser as they are wind proof and dry out quickly - jeans are not something I would recommend for that reason -expect to get wet
It's good fun though as long as you don't mind potential photographic disappointment
Hope this helps
Stu
My Flickr site link
Gwyn
Posted 30/01/2012 - 21:18 Link
Roy
I know they are Roy. It was said tongue in cheek.
They are a fiver from SRS, and free postage for forum members. Order your filter from them at the same time.
Frogfish
Posted 30/01/2012 - 21:22 Link
Your 70-200 or 60-250 are going to be much better than the 55-300 which is a slow focusing lens and may have trouble finding focus before the animals disappear under the water again. They are also sharper and can easily be cropped to the same equivalent FL and still be at least as sharp.
Gwyn
Posted 30/01/2012 - 21:34 Link
But he doesn't have either of those lenses Frogfish. It seems a lot of money to spend on a lens he may only use that one time.
I'd rather have the extra reach too, tbh. The 60-250 is a superb lens, but it is slow at focussing on a K20D.
The Bigma worked just fine each time I went and that is a slow lens at 500, the weather was appalling in Boston and Seattle, but I still got some good shots with it.
One important thing Roy - don't spend all your time trying to get photos. Take the time to enjoy watching them without a lens between you and them. And don't be surprised if you don't come over all emotional when you do see them.
Frogfish
Posted 30/01/2012 - 21:45 Link
True Gwyn ... if it's only for the one outing then maybe it's possible to rent one ?
rscoote
Posted 01/02/2012 - 12:18 Link
Thanks for the advice everyone.
I think I'll stick with my 55-300mm unless I get a windfall between now and August and then I'd be tempted to go for a Sigma 70-200mm f/2.8 (non OS if I can find one) because I'm looking to get into sports photography (football specifically). Rainsleeve may come in handy there as well!
Roy
My PPG link
Edited by rscoote: 01/02/2012 - 12:18
