Warning about Ricoh Lenses,
Posted 29/07/2011 - 22:13
The pin only appears on Ricoh's equivalent to Pentax PKA type lens the "P" type lenses i.e. aperture setting from the camera.
Barrie - Too Old To Die Young
Posted 29/07/2011 - 22:48
Posted 01/08/2011 - 10:27
Easy job to remove the pin, just don't stick it on the camera until you have modified it, they are a nightmare to get off trust me
Pentax k-5
Metz 50 AF-1
Pentax SMC 50mm 1.4
Sigma 70mm 2.8 MACRO
Sigma 17mm-70mm F2.8 - 4
Pentax 18mm-55mm f3.5-56 DA WR
Pentax 50mm-200mm f3.5-5.6 DA WR
Metz 50 AF-1
Pentax SMC 50mm 1.4
Posted 01/08/2011 - 13:29
Some Ricoh lenses have a rounded pin - these ones have always been fine on my K20D and K5. I've had 4 of these.
I believe it is the Ricoh lenses with a flat-ended pin that you have to watch out for. I've never actually seen one of this type.
Tim
Posted 03/08/2011 - 10:52
My S1 Vivitar 28-70mm (sold as Pentax-fit on Ebay!) didn't jam on the camera, and the pin did seem to be rounded.
But I soon removed it. It's very easy to do.
Posted 10/09/2012 - 20:59
I have just received a Sigma Mini Wide II with a P/KR mount, i.e. with the dreaded Ricoh Pin !Some Ricoh lenses have a rounded pin - these ones have always been fine on my K20D and K5. I've had 4 of these.
However, I noted 3 things:-
1) that it is a small Rounded topped pin
2) that the pin only protrudes a VERY small distance above the mount, and
3) it only requires EXTREMELY light force to push it back.
The combination of these gave me confidence to fit it onto my K-r and when I then tried to remove it there was absolutely NO restistance and you wouldn't have known the pin was there !
I then tried fitting and removing the lens again with the same result - OK !
Hopefully this situation will remain.
Posted 10/09/2012 - 21:13
Also I believe it is not issue with XR Rikenons. Correct me if I'm wrong.
Posted 10/09/2012 - 22:09
rparmar wrote:
It's no big deal to remove the dreaded pin. Banish your fears and read on!
The Ricoh Pin Fix
I have used loads of lenses with the Ricoh pin on Pentax AF cameras (SFXn & Z-1) without any problems. Most independent manual focus 'KA' lenses also had similar pins (some more rounded than others). I never had a problem getting them off again. When I bought my K-5 I did follow the link above to remove all the Ricoh pins from my lenses (just in case).
The Ricoh Pin Fix
Since the linking of Pentax name with Ricoh I have noticed a lot more Ricoh Ricohmar lenses for sale on eBay, Am I right in thinking that these lenses will fit onto Pentax DSLRs BUT NOT COME OFF AGAIN as a pin pops into the auto focus hole on the camera mount.
I have read of one guy having to hacksaw a Ricoh lens off of his Pentax DSLR.
K5+Bigma+BushHawk Shoulderpod.
K5+16-50DA* + 10-17DA Fisheye + 50-135DA* + Sigma 70mm Macro + DA35 2.4..
Slik Pro 700DX tripod.
https://www.flickr.com/photos/pixellie/
