viewing images fhile using the camera
mostar
Posted 26/07/2009 - 12:06 Link
trying to work out how to connect my pentax k200 with my pc and let a client view the shots as i take them
yelvertoft
Posted 26/07/2009 - 12:28 Link
As the K200D does not support the Remote Assistant feature (K10D and K20D only as far as I know), then I don't think you can do what you want.
geclinke
Posted 26/07/2009 - 12:57 Link
Doesn't the K200d support TV out? That might be an easier option - I've never tried it, but I would assume you see what's on the camera LCD on a TV screen? Not going to be fantastic resolution, but probably less faffing than taking out memory cards or downloading from the camera through the serial cable.
k5, 50mm FA, 18-55mm Kit, 50-200mm DA, 15mm Fisheye Sigma, 10-17mm DA Fisheye, 18-55mm DA WR, DA* 60-250, DA* 16-50
GlynM
Posted 26/07/2009 - 15:28 Link
geclinke wrote:
Doesn't the K200d support TV out? ...
If its like the K10D then when you connect the video output the on-board screen is disabled. A TV (composite) output is also not very high resolution making the pictures look a bit soft.
The K-7 has an HDMI output allowing an HD output, which does look good, but again disables the on-board LCD when in use.
Glyn
Edited by GlynM: 26/07/2009 - 15:30
