Viewfinder magnification?
I'm assuming that the physics of the matter is that crop-frame sensor cameras have smaller viewfinders than full-frame.
Comparing the two camera viewfinders the OM-2 has a magnification of 0.92 and a field of view of 97%. The K5ll is 0.92 and 100%
Using a 50mm lens on the OM2, and a 35mm lens on the K5, the image is the same size within the frame, of course, but it fills the viewfinder on the OM2, whereas it appears smaller in the K5 viewfinder.
Ok, so as said, it's a funny question . . but I do feel the difference.
looking at the above diagrams - I'm not great on physics - but I guess it is the internal space by which the light has to travel, which dictates the maximum 'size' to which it can be projected on the viewfinder. So a larger body allows for greater distance for light path to travel, and therefore greater projected size - ?
And Bill, thanks for the link to this magnification attachment, perhaps it'll make the difference I'm thinking about... I'll try and find a shop that has one I can try out!
If the mirror box and viewfinder were no different in size between the APS-C and 35mm formats, Pentax-Ricoh could have dropped a 35mm format sensor in an istD onwards.
But is that increase in image size not "compressed" to fit the same size oblong of the viewfinder window
To see this, just look through a DSLR and then through an SLR and it's very clear.
Viewfinder magnification is of course a factor, so, say on a film camera, a viewfinder with 0.86x magnification will look smaller than one with 1x magnification.
Another factor is viewfinder coverage. It costs more to show 100% of the image recorded as this requires higher accuracy in assembly.
Though is there anything on the market that I can purchase that'll give me the same viewfinder 'experience' with my K5 II ?
I wouldn't add anything to the finder, even if something were available, it would probably add bulk as well as expense. And proper quality would be definitely expensive.
many thanks,
Forbes
Cheers.
Philip
It would be interesting to hear from someone who uses one of those eyecups in Bill's link - 1.2x magnification doesn't seem much but does it significantly improve the view?
Cheers.
Philip
If you're interested keep an eye out in the classifieds as they do come up at reasonable prices from time to time
but you do have to work your way around the frame a little sometimes.
Don't know whether this makes sense or not :
12 years
So, I've no intention of moving systems, or for forking out for the Pentax full frame whenever that'll come out, but I wanted to know - is there anyway (any add-on gadget) that magnifies the viewfinder image of a crop-sensor DSLR? And, if so, one that'll work on a Pentax ?
Weird question I know, but I thought I'd throw it out there....
